jay
2 stroke or not 2 stroke
Post by jay on Jul 12, 2020 18:15:31 GMT 1
Where is the dash light supposed to be spurred off on 4lo clocks all I seem to have on the tacho side is wires for temp gauge and neutral light Regards Jay
Post by wangwang on Jul 12, 2020 20:41:09 GMT 1
You've got all the right wires, just needs tidying up a bit. Warning light loom goes over the inner side of the speedo, speedo dash light and tacho loom go over the inner side of the tacho.
Post by wangwang on Jul 12, 2020 20:44:31 GMT 1
Just re read the post, the tacho dash light should be in the separate tacho loom, blue and black wires.
jay
Post by jay on Jul 12, 2020 21:21:46 GMT 1
Just re read the post, the tacho dash light should be in the separate tacho loom, blue and black wires. if I use the blue and black wire bulb holder on the tacho side I will only have park light when in neutral the speedo side park light has black and blue trace wire or else the wires are wrong
Post by wangwang on Jul 12, 2020 21:25:54 GMT 1
Just blown up you pic to get a better look. The blue and black bulb holder in the bottom slot on the warning panel shouldn't be in there, that is the dash light for the tacho. That bottom slot is for Jap home market bikes.
Post by wangwang on Jul 12, 2020 21:30:26 GMT 1
If you want to pm an email address, I'll send a pic of where the wires should be.
jay
Post by jay on Jul 12, 2020 23:27:36 GMT 1
which wires are for the neutral light on dash
Post by lcmarky on Jul 13, 2020 17:03:27 GMT 1
which wires are for the neutral light on dash light blue is earth and brown is +12v
Post by lcmarky on Jul 13, 2020 17:04:07 GMT 1
look to be in the correct hole to me
jay
Post by jay on Jul 14, 2020 21:18:40 GMT 1
All sorted now thanks for all your help Regards Jay
Post by 4l04ever on Jul 14, 2020 22:31:32 GMT 1
Just blown up you pic to get a better look. The blue and black bulb holder in the bottom slot on the warning panel shouldn't be in there, that is the dash light for the tacho. That bottom slot is for Jap home market bikes. Wrong hole! ;-)
