Post by bodgerbedge on Jul 11, 2020 9:39:25 GMT 1
Having refurbished my callipers and now reassembled them, I notice that they are a little wobbly on the securing pin that goes through the calliper body and the fixed bracket on the fork. I have measured the pin at 8.1mm diameter and the hole at 8.5mm so this can create some play. Is this correct? Should there be some rattle in them if you shake them? The brakes stop perfectly well and the cylinders retract on brake lever release but they do seem to back off enough to leave a small gap of about 1mm between the disc and both pads. If I push the bike back and forth you can hear them clicking. I am just wondering if the hole for the pin is worn. Both sets of callipers measure exactly the same.
Post by oldelsieboy on Jul 11, 2020 9:51:39 GMT 1
Having refurbished my callipers and now reassembled them, I notice that they are a little wobbly on the securing pin that goes through the calliper body and the fixed bracket on the fork. I have measured the pin at 8.1mm diameter and the hole at 8.5mm so this can create some play. Is this correct? Should there be some rattle in them if you shake them? The brakes stop perfectly well and the cylinders retract on brake lever release but they do seem to back off enough to leave a small gap of about 1mm between the disc and both pads. If I push the bike back and forth you can hear them clicking. I am just wondering if the hole for the pin is worn. Both sets of callipers measure exactly the same. Are the calipers complete? Is the L shaped shim plate between the caliper body & hanger bracket fitted? OEB
Post by beardy on Jul 11, 2020 9:54:44 GMT 1
IMO nothing to worry about. There may be a service limit on the pins printed somewhere? I’ve done many miles on bikes with those type of callipers and the only thing apart from the rattle I’ve noticed is the pads wear slightly out of square. Obviously assuming all shims and springs are present.
Post by chrisg on Jul 11, 2020 11:41:35 GMT 1
There is also a little spring that is located in a blind hole.
Post by bodgerbedge on Jul 11, 2020 13:30:04 GMT 1
Ok. So I definitely don’t have the L shaped shim nor the other metal shim shown under the pin on the above picture. It appears that I also don’t have any springs anywhere! I have looked on fleabay and yambits and cant find any of these parts. Any ideas where I can get them from? Thanks.
Post by 4l04ever on Jul 11, 2020 20:24:12 GMT 1
You could get a one off pin made if you want to reduce the play.
Post by chrisg on Jul 12, 2020 9:31:03 GMT 1
There are all so 2 seals that fit in the little carrier plate that the pin slides on, Norbo sells them.
Post by chrisg on Jul 12, 2020 17:18:09 GMT 1
There are also 2 seals that fit in the little carrier plate that the pin slides on, Norbo sells them.
Post by bodgerbedge on Jul 20, 2020 9:34:22 GMT 1
Hi. I have been searching for the brake caliper / pads shims with no success! eBay, Yambits, Fowlers, etc. don't show anything. Any ideas where I can get these from? Part numbers, prices, etc. would be very useful. Thanks
Post by chrisg on Jul 20, 2020 14:31:01 GMT 1
Hi. I have been searching for the brake caliper / pads shims with no success! eBay, Yambits, Fowlers, etc. don't show anything. Any ideas where I can get these from? Part numbers, prices, etc. would be very useful. Thanks You may have to buy a second hand Caliper. Not many people will split them up and sell bits. You could try RDjames or moist on eb.
Post by oldelsieboy on Jul 20, 2020 17:27:33 GMT 1
Hi. I have been searching for the brake caliper / pads shims with no success! eBay, Yambits, Fowlers, etc. don't show anything. Any ideas where I can get these from? Part numbers, prices, etc. would be very useful. Thanks The parts you require all can as part of the original OEM brake pad kits which unfortunately are now NLA but can usually be found on eBay OEB
Post by Gitram on Jul 20, 2020 17:37:57 GMT 1
I had thought that there was someone on the forum who was making the shims a while back now..
marti
Post by rich on Jul 20, 2020 17:40:20 GMT 1
I made my shim from a piece of old baccy tin
Post by biffa on Jul 21, 2020 10:06:06 GMT 1
I had thought that there was someone on the forum who was making the shims a while back now.. marti I think vic6169 on here was looking at making some. He borrowed a shim from me to copy (and returned it very quickly 👍).
Post by bodgerbedge on Jul 21, 2020 10:50:34 GMT 1
Does anyone have a sketch / dimensions for them. I can make some up if necessary.
Post by chrisg on Jul 21, 2020 15:16:21 GMT 1
Vernier callipers showing 0.1mm thick Hope this helps.
Post by bodgerbedge on Jul 22, 2020 10:17:56 GMT 1
Great. Thanks. I guess it's completely flat? Is there a second U shaped shim like that shown in the right hand part of teh above photo?
Post by chrisg on Jul 22, 2020 13:50:44 GMT 1
Yes, I think that stops the pads from rattling about. Unfortunately my calliper is on the bike now.
Post by shergar on Jul 23, 2020 21:41:29 GMT 1
There is also a little spring that is located in a blind hole. can i ask where exactly is this spring fitted as i have a problem with movement with my lc250 caliper even though all shims ect are fitted ? ta
Post by chrisg on Jul 23, 2020 22:25:43 GMT 1
It pushes on the shim plate and takes any slack up. I guess its about 3.5mm dia.
Post by shergar on Jul 24, 2020 22:45:33 GMT 1
have you any pics by any chance as the parts list dosent show a spring . how many shims should there be in the caliper i have 1 little small one and 1 big flat one but again the parts list says there should be another from what i can make out of it ? my caliper moves way to much to be correct . sorry bodgerbedge hope you dont mind me kidnapping your thread mate , p
Post by shergar on Jul 25, 2020 21:03:04 GMT 1
any help on this issue men ?
