Post by rd50084matt on Oct 8, 2009 14:55:18 GMT 1
Ok well im getting there now connected 90% of loom and electrical bits BUT
the new loom i have (igm mk2/3 type)has got a 5 pin block towards the rear,and a 2 pin block(br/bl)that appear not to connect to anything?
their is a 5 pin block up near the front of the loom located next to pick up coil block which would match the rear but they are too far apart?it also has a rubber kind of protector around these two blocks,the old loom didnt,
wiring diagramme doesnt appear to show these two blocks,any ideas anyone,is it something to do with ypvs stuff that i dont need?
any help/ideas/pics appreciated
thanks
matt
Post by mellow on Oct 8, 2009 16:14:41 GMT 1
Thats a mk3 loom mate. Yes the extra connectors are for the ypvs controller etc Im sure gaz will be in to clarify this l8r and give u more detail
Post by rd50084matt on Oct 8, 2009 16:22:27 GMT 1
Hope so..lol..just wanted clarification so im not missing something,the mk2/3 looms are the same then itake it apart from ypvs stuff??
Post by mellow on Oct 8, 2009 17:13:57 GMT 1
pretty much m8 yeah.........enter gaz to correct me ;D
Post by rd50084matt on Oct 8, 2009 20:05:44 GMT 1
Thanks Gaz
soo basically i can ignore both plugs and the single b/w wire,everything else should be ok and connect up as per wiring diagramme?
Chhers
matt
Post by rd50084matt on Oct 8, 2009 20:21:00 GMT 1
Thanks Gaz didnt want to start routing it/connecting up fully if there was an issue with it,hopefully ill get battery connected up weekend see what works..lol
REGARDS
Matt
