Post by 46ob on Jul 4, 2020 14:22:41 GMT 1
Wondering if my clutch cable a genuine part? Its marked 4L0-00 3H22 in white about 3 inch after the handlebar adjuster. Do pattern cables also have these markings? Cheers!
Post by wangwang on Jul 4, 2020 15:32:41 GMT 1
My genuine one is 4L0-00 7J06 marked about the same point.
Post by 46ob on Jul 4, 2020 19:53:14 GMT 1
Thanks for that,just seen one on the bay,part number is listed correct at 4L0 26335-00 and that one is marked on the cable as 4L0-00 9F07..perhaps different markings for different production years??...just trying to solve a clutch stiffness issue & seeing if i already have a genuine cable on the bike.
Post by wangwang on Jul 4, 2020 20:13:37 GMT 1
It solved mine, it took two hands to pull in before the cable was changed, now spot on.
Post by 46ob on Jul 4, 2020 20:43:49 GMT 1
Sounds good & Im doing the same-i did order a new cable last week but it never arrived so will order another now. Cheers.
Post by JonW on Jul 5, 2020 2:07:18 GMT 1
Supersceeds to the 360 code now from what ive seen. Cheap solution too, OEM clutch cables are not silly money.
