Post by jon on Jun 29, 2020 9:18:03 GMT 1
Hi,
Can anyone measure a few things to do with an LC indicator pinch bolt please.
I have a pinch bolt here that measures 25mm from under the head of the bolt to the small shoulder before the M5 thread.
I have pattern indicators that measure 28mm high and a 3mm gap in the slot when unclamped.
That basically means the slot is fully closed up when the bolt is in.
Is this right?
Post by jon on Jun 29, 2020 9:58:36 GMT 1
Perhaps someone has a genuine indicator and they can see whether the gap is fully closed up.
Post by rich on Jun 29, 2020 10:10:04 GMT 1
No there should be a gap as the shoulder locks the nut
Post by rich on Jun 29, 2020 10:10:41 GMT 1
Pattern or genuine indicators should both have a gap
Post by jon on Jun 29, 2020 10:16:18 GMT 1
Pattern or genuine indicators should both have a gap Hi rich, How big do you think the gap is? Maybe 1mm? Jon
Post by flames on Jun 29, 2020 10:48:28 GMT 1
Stupid question, but you have got the rubber inserts fitted on the stalk / in indicator?
This would make a difference.
Post by jon on Jun 29, 2020 11:50:17 GMT 1
Yes rubbers are in.
Does anyone have a measurement of the bolt?
Post by flames on Jun 29, 2020 11:58:32 GMT 1
Will have a look tonight if no-one has come back to you in the meantime.
Post by Yogi on Jun 29, 2020 15:45:40 GMT 1
Hi Jon
The bolt measures 25mm from below head to shoulder The indicator is 26mm when bolted closed With 1mm recess either end where the bolt head and the washer sink into
Matt
Post by flames on Jun 29, 2020 18:26:30 GMT 1
I see measurements have been posted. Here is a pick of mine done up.... DSC_0127 by Neil Cleland, on Flickr
