steev
Post by steev on Jun 22, 2020 15:40:57 GMT 1
Hi All,
just rebuilding the engine (which arrived in boxes!) the reed blocks have a little tab at one side, is this to determine the correct way up please? and which way would be correct?
Thank you..
Post by rich on Jun 22, 2020 16:14:12 GMT 1
Don't think it matters but I always fitted them with the tab facing outwards. I assume they are to tap or lever against if the reed block is stuck to the barrel to save damaging the sealing surface. YPVS reed blocks don't have them.
steev
Post by steev on Jun 22, 2020 17:35:37 GMT 1
Great thank you Rich
Post by 4l04ever on Jun 22, 2020 20:33:46 GMT 1
I usually fit them on the outside too, but on the last one, I polished the edges, which meant they actually looked better with the tabs in the middle.
