Post by paddy1000rr on Jun 13, 2020 20:45:08 GMT 1
Need some help with the wiring for my 31k. I've been putting her together and the previous owner for some reason was messing around with the loom. I've it nearly all sorted but when I got the engine back and fitted it the ignition wires (3 white and 1 blue) were cut and had tape on the ends. The same for the wires they are supposed to plug into on the main loom. So has anyone any idea how I go about knowing which wires go to which and will I do damage if it's the wrong order. Cheers
Post by muttsnuts on Jun 13, 2020 20:48:05 GMT 1
3 whites just go to the 3 whites on the loom, any order, the blue wire is the neutral light and goes to the same coloured wire in the loom
Post by paddy1000rr on Jun 13, 2020 20:51:34 GMT 1
3 whites just go to the 3 whites on the loom, any order, the blue wire is the neutral light and goes to the same coloured wire in the loom Thanks mate. Was worried there was a certain order they had to go and if fry it lol.
Post by rich on Jun 13, 2020 21:57:56 GMT 1
As Dave said it doesn't matter. The 3 white wires are the 3 phase output from the generator into the rectifier so can be in any order.
