Post by nokturnal on May 21, 2020 18:05:23 GMT 1
There's also Bloke on ebay selling special Machined Bushes for £30? Anyone tried one yet!?!? Sean G He’s on the forum now. I asked him to join as I need a couple, and figured it would make him more money than being raped by eBay. Think he is out of material at the moment.
Post by nick2020 on May 21, 2020 21:59:47 GMT 1
Is the wear in this collar the main cause of excessive movement on the shaft or is it likely to be anything else ?
Post by dusty350 on May 21, 2020 22:04:04 GMT 1
The Lc doesn't have a steel bush fitted as standard like the Pv does. So the steel shaft on the gear change wears the ally housing it passes through, making it bigger and more likely to leak. You would notice more movement on the shaft too.
Dusty
Post by nick2020 on May 21, 2020 22:09:39 GMT 1
Thanks Dusty - what is considered the best fix?
Post by dusty350 on May 22, 2020 7:11:49 GMT 1
It depends what state you engine is in. If it's out of the bike, ready for a bottom end strip, I would buy the steel bush insert from Norbo and get that fitted - always done it on Lc builds at the very start. I have the engineering guy close by so it's an easy, and cheap fix for me to get him to do it. I did buy a reemer once but didn't trust myself to do it accurately - if you mess it up you end up with a bigger problem, so in a lot of respects, the £30 bush could be a better bet - definitely if your bike is up and running and doesn't need stripping. I bought one for my 400e as the case doesn't have a steel bush. I haven't fitted it yet as the 400 has a circlip and groove which needs re positioning on the side where the external bush would go. A job that would get done only if the original proves leaky. Dusty
Post by midlifecrisisrd on May 22, 2020 9:21:52 GMT 1
As Dusty says if the engine is out...
Mutts does the bush mod for £25
£10 post each way so £45 and it's as good as new and you happen to put another 30k miles on it (🤣) Its replaceable again
As for the £30 bush/seal repair if it sorts the leak and stops you having to buy or repair a shaft then that's fine
Giving the conversation on another thread about the genny connector "not being original" I reckon some would turn their nose up
It gets around the problem, not fixes it
Good thinking though 👍
Post by normanoo4 on May 22, 2020 22:11:02 GMT 1
Hi guys I'm the guy who makes the bushes to fix the leaks. It started on my boys bike and thought it be nice to help get rid of some of those damp batches. Any questions please ask. I can also bush casing if your engine is stripped. I have a small engineering workshop on canvey.
Post by earthman on May 22, 2020 22:15:43 GMT 1
Hi guys I'm the guy who makes the bushes to fix the leaks. It started on my boys bike and thought it be nice to help get rid of some of those damp batches. Any questions please ask. I can also bush casing if your engine is stripped. I have a small engineering workshop on canvey. Welcome to the forum. How often do you make/list them on ebay then?
Post by normanoo4 on May 22, 2020 22:30:07 GMT 1
Hi guys I'm the guy who makes the bushes to fix the leaks. It started on my boys bike and thought it be nice to help get rid of some of those damp batches. Any questions please ask. I can also bush casing if your engine is stripped. I have a small engineering workshop on canvey. Welcome to the forum. How often do you make/list them on ebay then? Thanks for the warm welcome. They are normally always on eBay unless i run out, then I would do a new batch. I have currently run out but will make a new batch next week ( work load permitting)
Post by rigga on May 22, 2020 22:49:44 GMT 1
I've got the bush, haven't fitted it as yet, but its there when I need it (got a cupboard full of stuff like that)
Post by tacky1 on May 22, 2020 23:50:34 GMT 1
Welcome to the forum. How often do you make/list them on ebay then? Thanks for the warm welcome. They are normally always on eBay unless i run out, then I would do a new batch. I have currently run out but will make a new batch next week ( work load permitting) Welcome aboard, I could do with 2 when you get back up and running, I live in the states now, so I would have to get them mailed over if that works.. P
Post by sp885 on May 23, 2020 2:29:42 GMT 1
Welcome to the forum. How often do you make/list them on ebay then? Thanks for the warm welcome. They are normally always on eBay unless i run out, then I would do a new batch. I have currently run out but will make a new batch next week ( work load permitting) I'd like to get one of these from you when you make some more, the listing you had on Ebay is finished at the moment so I'll keep an eye out for the next one, I'm in Sydney Australia if you send overseas, my bikes okay at the moment, but it's an LC so anything can happen at anytime Cheers Steve
Post by marrcel on May 23, 2020 6:37:32 GMT 1
Hi guys I'm the guy who makes the bushes to fix the leaks. It started on my boys bike and thought it be nice to help get rid of some of those damp batches. Any questions please ask. I can also bush casing if your engine is stripped. I have a small engineering workshop on canvey. Welcome to the forum. How often do you make/list them on ebay then? My ypvs leaks at the shift shaft. Does your bush fit a pv aswell?
Post by earthman on May 23, 2020 7:30:46 GMT 1
Thanks for the warm welcome. They are normally always on eBay unless i run out, then I would do a new batch. I have currently run out but will make a new batch next week ( work load permitting) I'd like to get one of these from you when you make some more, the listing you had on Ebay is finished at the moment so I'll keep an eye out for the next one, I'm in Sydney Australia if you send overseas, my bikes okay at the moment, but it's an LC so anything can happen at anytime Cheers Steve I'm thinking the same thing, would be handy to have one of these in the garage at least.
Post by dusty350 on May 23, 2020 7:37:56 GMT 1
Hi Welcome to the forum. I bought one - it's a great idea, and a perfect easy fix, especially on an engine that doesn't need stripping. Thanks for taking the time to produce them Dusty
Post by normanoo4 on May 23, 2020 11:16:52 GMT 1
Can i use this bush on a pv aswell? Hi Marrcel As long as the seal is 12 22 5 the yes.
Post by nick2020 on May 23, 2020 15:54:28 GMT 1
Thanks for your reply Dusty, and Norman when you make them I will take one, I will message you my contact details - thanks.
Post by nick2020 on May 24, 2020 17:08:12 GMT 1
Do these use the same oil seal size into the new bush?
Post by dusty350 on May 24, 2020 20:58:07 GMT 1
Yes Dusty
Post by normanoo4 on May 26, 2020 15:26:28 GMT 1
Hi I have a new batch of bushes if anyone is interested, please message me.
Post by nick2020 on May 29, 2020 20:56:33 GMT 1
Hi Nigel did you get my message/ PayPal?
Post by sp885 on May 30, 2020 22:45:23 GMT 1
Hi I have a new batch of bushes if anyone is interested, please message me. Sent you a message about getting one of these mate Cheers Steve
Post by nick2020 on May 30, 2020 23:04:58 GMT 1
All turned up as promised- thanks
Post by steelerd on May 31, 2020 0:55:58 GMT 1
That's a great find well done mate
Post by johnnyc1970 on May 31, 2020 10:31:28 GMT 1
Hi guys I'm the guy who makes the bushes to fix the leaks. It started on my boys bike and thought it be nice to help get rid of some of those damp batches. Any questions please ask. I can also bush casing if your engine is stripped. I have a small engineering workshop on canvey. Welcome to the forum. How often do you make/list them on ebay then? Hi there, I will have 2 when you make a new batch! Cheers 😀
