Post by headcoats on May 15, 2020 11:12:08 GMT 1
Is it a job for a specialist to change out the chrome stanchion ?
Is there a grub screw that always rounds and needs drilling out and it's threaded in with some permanent Loctite LOL
Post by midlifecrisisrd on May 15, 2020 13:09:29 GMT 1
I'll give you a clue
Never even thought of doing it myself 🤣
Post by LC_BOTT on May 15, 2020 13:16:22 GMT 1
Is there a grub screw that always rounds and needs drilling out and it's threaded in with some permanent Loctite LOL I was going to send mine to The Tuning Works and get them done there. I thought when I'd bought my replacements they came with the alloy bottom still attached. www.thetuningworks.co.uk/assets/Fork%20Services.pdfWould think they are a DIY job if you take your time.
Post by Yogi on May 15, 2020 13:18:49 GMT 1
I’ve done it myself even though they say it can’t be done
Warm around the grub screw before trying to get it out and warm the bottoms before trying to unscrew
I stripped mine and had them rechromed,you will need new orings to reassemble
Post by headcoats on May 15, 2020 13:53:37 GMT 1
The left side is excellent but right side is not so and a lot of the marks are at the bottom , not in the seal area, there is the odd one of concern I have polished and scotchbrited the area and you can hardly feel it with your nail now, so a dilemma
Post by headcoats on May 15, 2020 14:41:55 GMT 1
Anyone got a right fork with a good stanchion or just the right side alloy bottom section please ?
Post by Deleted on May 15, 2020 17:57:36 GMT 1
M or N, they are different ?
Post by headcoats on May 15, 2020 18:06:28 GMT 1
It's the ones that don't have the detachable bit on the upper alloy section
Aren't the bottoms the same then ?
Looked on Fowlers and the "M" model is on it's own with the detachable bit and the chrome stanchions have different part numbers to the others
M Model 51110-22D00 51120-22D00
The other ones which they say are N-P-R-T models and they all share the same lowers
N-P-R-T Models
51110-22D30 51120-22D30
Post by Deleted on May 15, 2020 19:45:11 GMT 1
The lowers (caliper carrier) and chrome stanchion are the same (M and N), it's the uppers and internals that are different. The VJ22/SP2 has different everything as it has rebound adjustment on the lower leg.
Having said all that no I don't have any spares.
Post by steeley on May 15, 2020 20:08:46 GMT 1
Years ago pulled mine apart, chrome was shot . yes grub screws buggered ,ended up drilling out and tapping out larger to fit some button head stainless screws . Apart from that easy enough to strip down . Had Phillpots do the chrome .
