Post by headcoats on May 14, 2020 8:36:49 GMT 1
Can you get the electrics in one hole or has anyone attempted to put an opening on the top too on the aftermarket headlamp shells
They are too shiny too, so has anyone de shined one LOL
Post by shaunthe2nd on May 14, 2020 15:09:38 GMT 1
The upper hole is easy to drill with a hole saw drill bit, done a couple before. Never bothered dulling them off though, maybe try rubbing a G3 compound lightly in, or a bit of brasso. Try it where can't be seen first though.
Post by headcoats on May 14, 2020 15:14:19 GMT 1
It's something you could buy genuine new only a few years back too
Radiator guards will be next !
Speaking of, can you fit a standard radiator guard on one of these Chinese radiators ?
Post by wangwang on May 14, 2020 21:42:47 GMT 1
It's something you could buy genuine new only a few years back too Radiator guards will be next ! Speaking of, can you fit a standard radiator guard on one of these Chinese radiators ? Yes
Post by headcoats on May 14, 2020 21:45:29 GMT 1
Any fiddling about !
Post by wangwang on May 14, 2020 22:01:43 GMT 1
I think the captive nuts on the radiator are one size larger
Post by Norbo on May 15, 2020 11:34:09 GMT 1
Iv had to cut out a holl at the top a few times its not hard just mark out with pen and drill a holl then dremel it out
Post by wangwang on May 15, 2020 13:05:24 GMT 1
Iv had to cut out a holl at the top a few times its not hard just mark out with pen and drill a holl then dremel it out I didn't need to adjust the rad guard, the larger bolts went through ok. If you PM an email address I'll let you have pics.
