Post by veg on May 12, 2020 15:43:49 GMT 1
This will be a slow burn built to a budget. I have wanted for many years to build a twin shock Lc flat tracker like the tz powered flat trackers Yamaha raced in the 70’s in champion frames. I have kept my eyes open and bought a few items and lost some. I know I bought a set of wire wheeled hubs on here about 5 years ago but having moved garage several times I’m buggered if I can find them. So I have recently bought an air cooled RD250 frame 1A2 for a good price and I have collected today a 1A2 bottom end. I will be going along the lines of Lc barrels so obviously will need to fit a radiator and use an Lc side case with oil pump and water pump. It will be twin shocked with wire wheels and a day time mot as I won’t be fitting lights etc The motor will be pretty std as I’m not tuning it nor am I fitting tz barrels. Having fitted tz barrels to my Lc I can’t justify the ridiculous costs (£2k plus) I want this as simple as possible so minimal electrics, dry cell battery etc So for now I’m gathering bits and we will see how we get on. As normal I’m pretty time poor being self employed but I will do my best to get it finished in the time it takes Steve and dusty to build 2 bikes but Matt will probably have built 3.
Post by 4l04ever on May 12, 2020 16:10:22 GMT 1
May be worth getting an Ignitech to run the engine side of things. Not much wiring for an AC engine :-)
Post by oldbritguy on May 12, 2020 17:17:03 GMT 1
This sounds nice Veg I had a similar thought with my current LC project to be a slow burner but I am an impatient bug*er and have foolishly bolted off the mark. With the help of lockdown though I have ground to a bit of a standstill but I will watch your own progress and use you as a pace setter once we get going again Keep safe John
Post by dusty350 on May 12, 2020 19:44:45 GMT 1
Looking forward to this build Veg. Especially interested in the Lc top end conversion. Have you planned what bodywork/tank you are going to fit ? Dusty
Post by Tobyjugs on May 12, 2020 19:59:30 GMT 1
Hi Veg I'm looking forward to this project.
Post by veg on May 12, 2020 20:06:19 GMT 1
Thanks chaps, it won’t be a fast build I’m pretty sure of that, I will follow advice re Lc top end, which appears to be Lc side case with Lc oil and water pump etc, bodywork is going to be a champion fuel tank and champion seat unit.
Post by midlifecrisisrd on May 12, 2020 20:09:52 GMT 1
You've had enough time now
Get on with it 😂
Post by veg on May 12, 2020 20:27:55 GMT 1
Already on it Steve on eBay as we speak. Had some great advice from an elder Lc owner who still thinks like a child (thanks Nigel).
Post by donkeychomp on May 12, 2020 22:04:36 GMT 1
Champion!
Post by veg on May 13, 2020 22:02:04 GMT 1
So got a front wheel tdr250, hoping to have lined up some new alloy rims and just waiting on front forks tzr250 2ma with yokes and disc. So next thing is decision on swing arm and then wheels off for building. Going to have to get a comprehensive list together of bits needed and also make a decision re barrels, do I go cheaper 4L1 or push the boat out and go for 350 barrels?
Post by midlifecrisisrd on May 13, 2020 22:33:02 GMT 1
Push the boat out and go 350 😁
What rear hub you using? Drum or real old school disc?
Post by dusty350 on May 14, 2020 6:40:55 GMT 1
350 barrels Veg . Dusty
Post by veg on May 17, 2020 13:12:36 GMT 1
Really do need to post some pics, managed to get an ac rear wheel with disc hub, big shout out to ReedPete for that he is a top man, picked up a box section swing arm which is exactly what i wanted and oeb has come good with rims etc. In the process of gathering more bits so not too much to report otherwise. Will be sending of the hubs soon enough for new and spangly rebuilds. This is taking a significant move forward and i will be following Mr Millers rebuild thread and doing the motor myself, i know im barely literate in the spanner wielding fields but i have built motors years ago just not recently so nowt ventured nowt gained.
Post by dusty350 on May 17, 2020 16:57:00 GMT 1
Which model aircooled bottom end did you end up with Veg ? Dusty
Post by yamark on May 17, 2020 18:17:57 GMT 1
I like the sound of this Veg, following with interest
Mark
Post by veg on May 17, 2020 18:48:39 GMT 1
Hi dusty it’s a 1A2 250 dx I believe looking at the engine number and not a million miles away from the chassis number. Thanks mark no pressure then from the alan millyard of the forum 😁
Post by tell7437 on May 18, 2020 10:19:40 GMT 1
The aircooled crankcases don't have a support for the waterpump shaft like the lc cases have, but it has been done before I'm just wondering how. Great project, I will be following this
Post by veg on May 18, 2020 12:24:06 GMT 1
Its all new to me and if it can't be done (by me) i will go with an electric pump, no big concerns i want this to be utilitarian and not just a show pony (obvs it has to look cool as feck as well . )
Post by dusty350 on May 18, 2020 19:37:56 GMT 1
I'd go for a modern digital ignition too - Mutts, Norbo and others sell them. Get rid of those archaic points !! Someone was selling a engine on Facebook earlier - 4l0 bottom end with a Tz350 top end, 34mm carbs etc. 2k. I will see if I can find the link Dusty
Post by dusty350 on May 18, 2020 19:44:28 GMT 1
Post by midlifecrisisrd on May 18, 2020 19:46:20 GMT 1
DUSTY !!!!!!
What you trying to do to him 🤣🤣
Post by dusty350 on May 18, 2020 19:47:05 GMT 1
It's a bargain Steve
Post by veg on May 18, 2020 20:35:06 GMT 1
It is a bloody bargain my tz top end on my Lc admittedly with all new everything cost me over £2500 that’s bloody cheap
Post by veg on May 18, 2020 20:48:54 GMT 1
But it’s a 350 not a 700 so it’s not reed valve
Post by veg on Jul 4, 2020 18:05:50 GMT 1
So I’ve sent the wheels off to cwc who quoted a 2 to4 week turn around that’s now going to take 8 weeks. Got my forks n disc from jon, yokes from dejan wanted tdr for the bar mounts they’ve got to go to Andy for stem transfer, got my dresda box swing arm and an Lc 250 top end from Mike and a radiator from Martin so it’s gathering momentum and will be time for some pics soon enough.
Post by bezzer on Jun 23, 2023 22:18:27 GMT 1
Any progress on the flat tracker build Veg?, really intrigued to see how it’ll turn out. Love the idea of it!!.
