Post by Delbert on May 8, 2020 10:20:55 GMT 1
Hi I need to make a new loom from the generator as it all been hacked about and joined in various places,is there anything special about the three white wires from the windings? Can I use normal auto electric cable and any idea on ratings please? ( I know its an air cooled 250 but thought the question would be across the board) Cheers
Post by midlifecrisisrd on May 8, 2020 10:28:34 GMT 1
Nothing special, just the same gauge as the original
Post by Delbert on May 8, 2020 10:57:55 GMT 1
Nothing special, just the same gauge as the original Steve thanks Steve always worth checking
Post by 4l04ever on May 8, 2020 13:54:57 GMT 1
I have seen that some bikes use a different type of insulation (silicon I think) and the soldered connection is done using high temperature melting point solder. You may need a variable temperature soldering iron and specific solder if you want to do this.
Post by risolc on May 8, 2020 15:06:00 GMT 1
I used silicone wire when I done mine, much more flexible when trying to thread it through the stator plate,but just regular solder with gas soldering iron on lower setting.
Post by midlifecrisisrd on May 8, 2020 15:11:17 GMT 1
The silicone wiring is usually to cope with the heat at the engine end
Post by Delbert on May 8, 2020 16:51:14 GMT 1
Thanks guys for your help , to be honest once I stripped the thing down I think anything will be better than what's there ! The 45 year old wiring is very brittle, I've ordered some wire that should do the job
