Post by liffy16 on May 5, 2020 20:15:12 GMT 1
Tap on my 250 is leaking from the bowl there's an o-ring that it seals against which has split,do the repair kits on eBay come with this ?
busby
RD 350 4l0
Post by busby on May 6, 2020 18:24:42 GMT 1
Mine did, although now I have done mine it leaks passed the tap when it is in the off position ☹️
Post by liffy16 on May 7, 2020 10:08:37 GMT 1
Thanks Busby mines only leaking when you turn it on was going to just stick a pattern tap on,but would like to try and keep the original tap
Post by Shytalk on May 7, 2020 12:01:56 GMT 1
Thanks Busby mines only leaking when you turn it on was going to just stick a pattern tap on,but would like to try and keep the original tap I think I have a complete bottom part of the tap assembly if you want it for spares?
Post by liffy16 on May 7, 2020 19:14:36 GMT 1
P'MD you shytalk
Post by petenofear on May 7, 2020 20:31:44 GMT 1
If you can get new just buy new , I got fed up with rebuild my tap and now just bought a new one from Norbo ,, job done
Post by JonW on May 8, 2020 0:30:02 GMT 1
Tourmax is the OEM for the LC, it is an LC youre talking about?
Post by Shytalk on May 8, 2020 10:46:42 GMT 1
Tourmax is the OEM for the LC, it is an LC youre talking about? PV Jon.
Post by JonW on May 8, 2020 13:41:57 GMT 1
Tourmax is the OEM for the LC, it is an LC youre talking about? PV Jon. Ahh ok, its not obvious by the question is all...
Post by liffy16 on May 8, 2020 15:53:38 GMT 1
Sorry 250lc
