Post by doohanno1 on May 3, 2020 19:03:45 GMT 1
Would anybody know if this is genuine oem cable.. Thanks..
Cable
May 3, 2020 19:05:04 GMT 1
via mobile
Post by doohanno1 on May 3, 2020 19:05:04 GMT 1
Sorry, meant to say for a 31k. Would aftermarket ones copy the part number. Tks.
Cable
May 3, 2020 20:39:59 GMT 1
Post by LC_BOTT on May 3, 2020 20:39:59 GMT 1
I think some of the HI-Level cables have the Yamaha numbers on them. What is that one in the pic, and does the part number match up??
Cable
May 3, 2020 21:13:38 GMT 1
via mobile
Post by doohanno1 on May 3, 2020 21:13:38 GMT 1
I think some of the HI-Level cables have the Yamaha numbers on them. What is that one in the pic, and does the part number match up?? I'm wondering what this one is off.I was told it a 31k but the number 2626000 pops into my head..I tried to search Fowlers website but had no luck
Cable
May 3, 2020 21:35:31 GMT 1
Post by LC_BOTT on May 3, 2020 21:35:31 GMT 1
Yes that's why I asked, number didn't really make sense, and as you say, 31k/29l? 26260-00
Cable
May 3, 2020 21:38:48 GMT 1
via mobile
Post by doohanno1 on May 3, 2020 21:38:48 GMT 1
Yes that's why I asked, number didn't really make sense, and as you say, 31k/29l? 26260-00 So we are saying the one in the picture in not a 31k cable.?
Cable
May 4, 2020 7:35:24 GMT 1
Post by LC_BOTT on May 4, 2020 7:35:24 GMT 1
Who knows, I'm no expert, but I'm guessing it's not a genuine Yamaha cable, not a very good pic either, but genuine ones are heading to £80-100 now if it's a throttle cable you're after.
Cable
May 4, 2020 8:47:54 GMT 1
via mobile
Post by midlifecrisisrd on May 4, 2020 8:47:54 GMT 1
29l is the correct prefix code for an lc2 31k throttle cable
The bike was first made as a 250 with the 29l model code
Usual indications if it is genuine is the inner cables to the carb slides have Teflon covering them and the adjuster AND elbow at the oil pump are olive green
Pattern cables are usually just zinc at the oil pump or a mix
Does it say 29l at the top too?
Suspect 51l cable may say 29l at carbs and 51l at throttle
Cable
May 4, 2020 11:47:00 GMT 1
via mobile
Post by doohanno1 on May 4, 2020 11:47:00 GMT 1
Don't have the cable in my posession but will pass on it just in case its wrong. Thanks for the help lads.
