Post by Dixie Dean on May 2, 2020 9:47:06 GMT 1
Hi everyone anybody have any experience of fitting one of norbos lc2 master cylinder sight glass?
Post by jon on May 2, 2020 9:52:14 GMT 1
I did. Works fine.
From memory the hardest part was removing the old one?
Post by Dixie Dean on May 2, 2020 9:53:40 GMT 1
Sorry should of said best way to fit them.
Post by Yogi on May 2, 2020 10:01:11 GMT 1
G-clamp and crossed fingers🤞
Post by Dixie Dean on May 2, 2020 10:14:47 GMT 1
Did you you use any rubber grease?
Post by muttsnuts on May 2, 2020 10:21:40 GMT 1
Did you you use any rubber grease? we still taking about sight glasses ........ !! oops sorry, couldn't resist !!
Post by Yogi on May 2, 2020 10:26:43 GMT 1
Did you you use any rubber grease? Lightly smeared the inside edge of the glass that touches the oring
Post by Dixie Dean on May 2, 2020 10:31:22 GMT 1
Had a funny feeling somebody would reply to that .
Post by speedar on May 2, 2020 11:01:51 GMT 1
Attempted this repair a couple of weeks ago on an F2 but on installing sight glass it pushed rubber o ring from groove causing brake fluid to leak! Bought 3 on Ebay for £5.64 in case any other install probs. www.ebay.co.uk/itm/1-Set-18mm-Master-Brake-Cylinder-Reservoir-Sight-Glass-Motorcycle-Dirt-Fast-UK/303378226663?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2Took a couple of weeks to arrive. I used red rubber grease on o ring at first attempt but on second attempt assembled dry. Used a G clamp but sight glass kept going in at an angle not square to hole. This seamed to help because sight glass then gripped o ring keeping it in groove. Just kept pressure on sight glass and it popped into place with o ring in groove. Result. Have filled master cylinder with brake fluid and no sign of a leak so far.
Post by Dixie Dean on May 2, 2020 12:03:36 GMT 1
Cheers mate
Post by Yogi on May 2, 2020 12:09:12 GMT 1
I did. Works fine. From memory the hardest part was removing the old one? Jon I’ve always got the old ones out easily by using a small flat blade inside and turning it.
Post by jon on May 2, 2020 12:10:44 GMT 1
Last one I did was yellow and cracked. It just broke away and left the outer metal ring to get out.
Post by Yogi on May 2, 2020 12:13:48 GMT 1
Last one I did was yellow and cracked. It just broke away and left the outer metal ring to get out. Jon Doh 🥴
Post by Dixie Dean on May 2, 2020 12:27:16 GMT 1
Yeah I did the same just concerned about putting new one in
Post by jon on May 2, 2020 12:29:14 GMT 1
Find a suitable socket and press it in in a vice.
jch
Post by jch on May 3, 2020 9:42:19 GMT 1
Can anyone confirm the size of the LC/LC2 sight glass?
Post by jon on May 3, 2020 9:50:33 GMT 1
18mm from memory, but stand to be corrected.
Post by stusco on May 3, 2020 10:00:08 GMT 1
18 mm i just ordered 4 yesterday need one today but the world is f##ked so its a month from China
jch
Post by jch on May 3, 2020 10:37:49 GMT 1
Oh really. I only hesitate as I read somewhere that the LC/LC2 rectangular ones were smaller and the later YPVS ones are bigger but can’t remember where I read that
Post by midlifecrisisrd on May 3, 2020 11:01:57 GMT 1
18 mm i just ordered 4 yesterday need one today but the world is f##ked so its a month from China Think I have a spare ypvs one 😉 Steve
Post by stusco on May 3, 2020 11:08:42 GMT 1
Thanks Steve i should still have a couple but can’t find them,found lots of other handy stuff though😃
Post by midlifecrisisrd on May 3, 2020 11:13:21 GMT 1
I'm the same hence all the bits in the for sale section 🤣
