Post by alankelly on Apr 26, 2020 21:53:56 GMT 1
Hi all Just a quick question Just been making up a part for the Rd air box and wondered what people thought and if anybody would be interesting such a part? It’s the frame members that support the foam filter but it’s an all in one unit so you don’t lose one of the supports Thinks cost will be around £5 that should include 1st class post Any comments welcome Best wishes and stay safe Al
Post by damiensk on Apr 26, 2020 21:58:55 GMT 1
looks spot on, good idea that its all in one, price sounds about right!!
Post by alankelly on Apr 26, 2020 22:00:54 GMT 1
Yes I did it this way as I heard a story once that one of the supports came out and wound up holding a carb slide open😳😳
Not sure how true but if it was this solves that issue👍
Post by shaunthe2nd on Apr 26, 2020 22:03:39 GMT 1
Great idea. There is no holding you back. Count me in for one if you make a few to sell.
Post by rich on Apr 26, 2020 22:19:50 GMT 1
What a great idea! (Although I have foam pods on mine so a'm oot, sorry)
Post by wangwang on Apr 26, 2020 22:21:22 GMT 1
I'd be in for a couple 👍
Post by allspeeds on Apr 26, 2020 22:31:36 GMT 1
Great idea you are on a roll now
Post by 4l04ever on Apr 26, 2020 23:44:10 GMT 1
Nice idea! :-)
Post by mattybeckett on Apr 27, 2020 3:12:42 GMT 1
+1 for me please.
Post by jon on Apr 27, 2020 8:29:48 GMT 1
I’ll take 2 please.
Better than original!
Post by rigga on Apr 27, 2020 10:50:29 GMT 1
That's a great idea, as said you're in a roll now with this printer malarky ..... whatever next
Post by doohanno1 on Apr 27, 2020 19:07:03 GMT 1
That's a great idea, as said you're in a roll now with this printer malarky ..... whatever next Clock needles....!!!!!
Post by donkeychomp on Apr 27, 2020 21:43:23 GMT 1
I do nag him about that... Alex
Post by alankelly on Apr 27, 2020 21:47:58 GMT 1
Ok ok ok I give in 🥺🥺
I can look to try and print a speedo needle
Trouble is it’s the fine detail but I will have a go
So question is does anybody please have a broken but complete one I can look at and measure so first I can create a model
No promises but let’s give it a go😁😁
Catch up all soon and stay safe Al
Post by donkeychomp on Apr 27, 2020 21:52:47 GMT 1
Yay! It's got to be worth a go Al. If it works, brilliant. If it doesn't...you tried and that's all we ask.
Post by alankelly on Apr 27, 2020 22:03:23 GMT 1
Hi Alex
Trouble is I’m crap at accepting failure at anything (It’s just me)
But I will give it a go
Once I have a needle and model I can then play around with the printer nozzle diameters and program etc to see what happens
Good thing is it’s not a big print so it’s not like I need to print for 15 hours and print fails in the last 2 righting off 13 hour print time and material which really pi55es me off☹️☹️
Also need to research what would be the best material to print the needles in
The slider seat tang nylon is great for parts that need strength but not good for fine detail as you observed Alex with the PLA seat tang
Post by donkeychomp on Apr 27, 2020 22:12:13 GMT 1
If I had a needle I'd send it to you mate. Someone here will. Ask in the wanted section. And like you said it won't take 15 hours to make!!
Post by shaunthe2nd on Apr 27, 2020 22:20:31 GMT 1
I will check my stash tomorrow to see if I kept a broken one, i certainly snapped a few!
Post by oldbritguy on Apr 28, 2020 9:02:22 GMT 1
Ok ok ok I give in 🥺🥺 I can look to try and print a speedo needle Trouble is it’s the fine detail but I will have a go So question is does anybody please have a broken but complete one I can look at and measure so first I can create a model No promises but let’s give it a go😁😁 Catch up all soon and stay safe Al Hi Al I have a broken needle which I will stick in with the clock cases and post off tomorrow. Needle has been snapped and poorly glued but is complete and should give you an idea of dimensions etc. Take care John
Post by alankelly on Apr 28, 2020 9:07:58 GMT 1
Hi John
That sounds like a plan and kills two birds with one stone as I can then also look at the ignition surround👍
Will let you know when the get here
Catch up soon and stay safe Al
Post by alankelly on Apr 28, 2020 9:26:14 GMT 1
Just been quickly trying to think how to print this needle and recon it will be a two piece part due to the different coloured parts If I can print it parts the assembly will look something like this mock up And once I get Johns needle (many thanks John) I will start my model then test prints Catch up soon and stay safe all Best wishes Al
Post by shaunthe2nd on Apr 28, 2020 10:42:47 GMT 1
Al, Sounds like you are sorted with a needle. If it falls through let me know and I will check my stock for you. Shaun.
ps - that was a quick model you put together.
Post by alankelly on Apr 28, 2020 10:52:46 GMT 1
Yes it’s only a mock up as just trying to work out the best approach to solve printing different colours 🤔
Once I have the model I have a few colours of ABS so can just then test and if successful I will then order a black and orange for the finished parts
Post by darboots on Apr 28, 2020 11:12:49 GMT 1
Not sure if 3D printing in a 'flexible' filament is possible, but I'd be well up for an LC2 headlight 'damper' rubber thingy.
May be better to make one from rim tape though??
Post by onewheelsenough on Apr 28, 2020 11:38:03 GMT 1
Yamaha must have known there was a problem with the airbox supports because one of my lc's have an all in one piece support fitted.
Post by oldelsieboy on Apr 28, 2020 11:58:45 GMT 1
Yamaha must have known there was a problem with the airbox supports because one of my lc's have an all in one piece support fitted. Ditto OEB
Post by alankelly on Apr 28, 2020 12:06:29 GMT 1
Maybe there was a safety issue raised in Yamaha like the story I heard earlier in the thread as no reason to change otherwise?
Post by onewheelsenough on Apr 28, 2020 12:15:02 GMT 1
Could I please have one for my other lc. Thanks gareth
Post by alankelly on Apr 28, 2020 12:42:29 GMT 1
Hi all
Ok looks like the filter support is a live project😁😁
Cost will be £5 that includes post
Now just put an order in for some filament as don’t have much at home as used most of it on the chain sliders project😁😁
Once I have a few I will pm you to sort address and payment
Best wishes All
Post by wangwang on Apr 28, 2020 12:53:33 GMT 1
Nice one, i'm loving this 3D printing :-)
