Post by philmill on Apr 25, 2020 17:09:24 GMT 1
So, I know somebody sorted this issue but I cant find the tread now so I'll ask . I am using the clocks from a N or TZR or whatever other models use the same on my 31K, but I have stumbled on a problem with the indicator "idiot" light, how it make it work with both side indicators. I can work it from one no problem, and of course I cannot join the green and brown together or I get all 4 indicators working at the same time so can somebody advise please?? Second is just confirmation really, to run the electronic tacho I just connect the grey wire from the tacho to the coil I believe, can someone confirm please. Thanks, Phil
Post by midlifecrisisrd on Apr 25, 2020 17:38:01 GMT 1
Hi
To get the indicators to operate the one idiot light you need to disconnect the black wire off the lamp holder and connect the other indicator feed to where the black wire was
Yes I know it means there are 2 positives to the bulb and no negative but it works
It must back feed through the other circuit
As for the tacho if it is a ypvs one you need to run a wire from the grey tacho feed to the trigger wire from the cdi to the pv controller
Off the top of my head it is the black/yellow
Post by philmill on Apr 25, 2020 18:05:04 GMT 1
Hi To get the indicators to operate the one idiot light you need to disconnect the black wire off the lamp holder and connect the other indicator feed to where the black wire was Yes I know it means there are 2 positives to the bulb and no negative but it works It must back feed through the other circuit As for the tacho if it is a ypvs one you need to run a wire from the grey tacho feed to the trigger wire from the cdi to the pv controller Off the top of my head it is the black/yellow Steve Hi Steve, thanks for the quick reply. I tried the indicators in that way but it made all four indicators flash together, actually it was the way the bulb holder is wired as in, it has one green and one brown wire. I am using LED indicators but I cant see that makes a difference? As for tacho, yes, the one I got off you
Post by midlifecrisisrd on Apr 25, 2020 19:10:21 GMT 1
It may be the led indys as there will be no load
I have 2 small 12v led's in the idiot light hole on my 385 to get round the issue
