Post by chrisg on Apr 22, 2020 15:34:42 GMT 1
I have searched and can only find LC2 trip meter know removal.
How does the trip meter know come off a 4L0. Is it screwed, LH or RH thread? or small grub screw?
Thanks
Post by wangwang on Apr 22, 2020 15:53:44 GMT 1
No grub screw. Comes off the opposite way to resetting the trip. It will most likely be a bugger to do though.
Post by Shytalk on Apr 22, 2020 16:21:19 GMT 1
As above, think that its hollow too and needs a very thin screwdriver down the middle to stop the shaft from spinning too.
Post by shaunthe2nd on Apr 22, 2020 16:25:19 GMT 1
As above but you need to remove the Speedo clock from the cluster to do this. Can be a bugga!
Post by chrisg on Apr 22, 2020 17:44:16 GMT 1
Thanks gents
Post by tony2stroke on Apr 22, 2020 18:14:44 GMT 1
Try pulling on the knob while turning it in the opposite direction to resetting, that normally works, or it does for me, don't pull too hard.
Post by rich on Apr 23, 2020 0:28:22 GMT 1
Always used the thin screwdriver method, the secret is to poke the screwdriver down the hole in the knob (this is making my eyes water typing this) and use it to hold the shaft still. Then unscrew the knob clockwise (it is a left hand thread) and it should pull through the rubber seal once its fully unscrewed.
Post by Jethro5 on Apr 23, 2020 0:29:52 GMT 1
Mine would not unscrew. However there is no secret. It was just stuck. I ended up holding the shaft with long nose pliers. You need to remove the face to get to the shaft.
Post by pdxjim on Apr 23, 2020 7:35:18 GMT 1
I beat my head against mine for a while and finally gave up.
This thread is giving me hope (just).
Post by midlifecrisisrd on Apr 23, 2020 9:03:02 GMT 1
I've had ones that near fell off and ones that I've had to take the bezel off and hold the shaft with long nose pliers
Post by wangwang on Apr 23, 2020 14:42:52 GMT 1
I've had ones that near fell off and ones that I've had to take the bezel off and hold the shaft with long nose pliers Steve Ditto
cnkxu1
Post by cnkxu1 on Mar 23, 2021 5:56:53 GMT 1
Glad I searched and found this thread as I have had the same problem about removing the trip knob. Thanks
Post by headcoats on Mar 23, 2021 8:13:07 GMT 1
Mine would not unscrew. However there is no secret. It was just stuck. I ended up holding the shaft with long nose pliers. You need to remove the face to get to the shaft. That's how i did mine Put some tape on plier faces to protect shaft
Post by chrisg on Mar 23, 2021 13:54:18 GMT 1
I ended up opening the unit up and using long nose pliers as stated.
Post by JonW on Mar 23, 2021 23:19:04 GMT 1
I've had ones that near fell off and ones that I've had to take the bezel off and hold the shaft with long nose pliers Steve this that Steve said is so true. They all seem to be different.
cnkxu1
Post by cnkxu1 on Jul 1, 2021 6:55:03 GMT 1
Glad I searched and found this thread as I have had the same problem about removing the trip knob. Thanks This wall plug will do the job until I can find a real one. Lol
Post by shaunthe2nd on Jul 1, 2021 8:04:10 GMT 1
Nice temp solution. Norbo sells copy trip knobs so worth giving him a shout.
Post by chrisg on Jul 1, 2021 12:15:33 GMT 1
Nice temp solution. Norbo sells copy trip knobs so worth giving him a shout. B and Q do them in the wall plug section 🤔
cnkxu1
Post by cnkxu1 on Jul 6, 2021 6:01:38 GMT 1
The reason I was searching the forum on removing the trip meter knob was I had to remove the PO’s effort.
