Post by petenofear on Apr 20, 2020 19:39:17 GMT 1
Bike all back together, had a fuel leak,
any way just done repair kit on fuel tap so that’s sort that problem, I think
done a full carb kit on both carbs and all was well then the left hand carb started to over flow , pulled apart the left had side again and all good but now the right had side is over flowing out the carb ,,,, but bike starts up runs but more smokey on left had side and bogging out and then I release it’s coming out the left exhaust ,, left exhaust is warm not hot like the right had side ,
pulled plug out on left had side and it’s born dry ,,
bike is getting right on my tits now
Post by jackjabba on Apr 20, 2020 20:03:28 GMT 1
I would fit genuine float valves as a starting point if you already haven't.
Post by petenofear on Apr 20, 2020 20:25:26 GMT 1
Where do you get genuine from these days ,,
Post by tony2stroke on Apr 20, 2020 20:32:07 GMT 1
Where do you get genuine from these days ,, Try Fowlers, after all they are a very common item used on many many bikes.
Post by beardy on Apr 20, 2020 20:38:32 GMT 1
I got genuine ones from Fowler’s last year. Also check float height and that floats are parallel to each other. Presumably you haven’t got debris coming from the tank.
Post by petenofear on Apr 20, 2020 20:51:17 GMT 1
Ok will do just bought a brand new kit for both cards of eBay as I wanted the complete kit and could not see that ion norbo site ,
Do you think a new set of reeds would help as well
Thanks all
Post by petenofear on Apr 20, 2020 20:52:49 GMT 1
I got genuine ones from Fowler’s last year. Also check float height and that floats are parallel to each other. Presumably you haven’t got debris coming from the tank. Tanks is spotless mate ,, bike was running A1 4 weeks ago ,, only pulled apart the bike to do a full tidy up
Post by looey on Apr 20, 2020 20:57:52 GMT 1
I normally get my genuine carb spares from Allens Performance. They sell genuine manufacturer parts but not with the uplift in price once they are in motorcycle manufacturer's bags with part numbers .
Post by petenofear on Apr 20, 2020 21:02:24 GMT 1
Allens or Norbo if you pm him Is it a vacuum tap I rebuilt mine on my lc2 must have f**ked up as it passed over night and filled the crank cases with fuel it also pissed out the overflow but only when running,bought a new tap all sorted Yes it’s a vacuum tap ,, rebuild it today as well as carbs so not had time come out over night ,, tap seems fine comes out on prime but not on res or on but bike runs on , on so must be working on the vacuum
Post by stusco on Apr 20, 2020 21:20:45 GMT 1
I had a double fault a faulty tap and passing needle valves and i had just removed the carbs from my lc with no issues so must have had dirty fuel ,bought a new tap and needles and all was good
Post by petenofear on Apr 20, 2020 21:27:18 GMT 1
If I get back at a sensible time tomorrow I am going to pull it all apart again
Post by tony2stroke on Apr 20, 2020 21:35:26 GMT 1
The needle valve should shut off the flow of petrol to carbs regardless of the vacuum tap IMO
Post by midlifecrisisrd on Apr 21, 2020 9:29:38 GMT 1
Ill second Allen's Performance
Also be aware that powerjet (F2) carbs have different needles and seats than non powerjet (31k)
Got caught out with this on my Jap 250 build. It totally fecks up the float levels and won't work
Your cylinders will be running different as one crankcase side probably has a nice puddle of fuel in it. It will clear
Now put your big boy pants on and get on with it 😜
Post by petenofear on Apr 21, 2020 10:04:47 GMT 1
Ill second Allen's Performance Also be aware that powerjet (F2) carbs have different needles and seats than non powerjet (31k) Got caught out with this on my Jap 250 build. It totally fecks up the float levels and won't work Your cylinders will be running different as one crankcase side probably has a nice puddle of fuel in it. It will clear Now put your big boy pants on and get on with it 😜 Steve Hahaha I will sweetheart lol
Post by marrcel on Apr 21, 2020 15:05:00 GMT 1
Left side too rich and bad vacuum on the tap? Check your l/r bowles first. They differ Check choke pipe. No leaks. Check your vac pipe. I ditched the vactap.
Post by petenofear on Apr 21, 2020 16:55:31 GMT 1
I would love to ditch the vac pipe but how
Post by mellow on Apr 21, 2020 17:04:19 GMT 1
Post by midlifecrisisrd on Apr 21, 2020 17:26:38 GMT 1
I would love to ditch the vac pipe but how Fit a 350R ypvs tap On, Off and Reserve only Bit rare to find though Steve
Post by marrcel on Apr 21, 2020 17:44:40 GMT 1
Norbo does 8mm taps. I have china tap. I had to convert it for the lc2 knob.
Post by allspeeds on Apr 21, 2020 21:39:34 GMT 1
Bin the power jets and get 31k carbs
Post by petenofear on Apr 21, 2020 22:42:54 GMT 1
Bin the power jets and get 31k carbs I am getting bloody lost now lol
Post by Gitram on Apr 21, 2020 23:32:11 GMT 1
i'm surprised that no one has said, "I'll have it if you don't want it..."
marti
Post by petenofear on Apr 22, 2020 10:16:45 GMT 1
i'm surprised that no one has said, "I'll have it if you don't want it..." marti Every think is for sale for the right money 👍
Post by petenofear on Apr 22, 2020 10:16:58 GMT 1
Post by Gitram on Apr 23, 2020 18:15:01 GMT 1
true enough.. tho I kinda made a deal with myself that I wouldn't buy another bike until I had sold two to clear some space..
marti
Post by petenofear on May 1, 2020 17:07:59 GMT 1
Had a half day today and thought I would pull carbs off again ,, Took apart again and thought this time I would measure the float height and they was way out the standard spec , unsure why as not done anything to then and bike was fine .
Put back together and bike a lot happier,, little smokey on left pipe ,,may be all the fuel in the exhaust,,,and the left hot but not as hot as the right , so maybe a little bit more playing with carbs and should be fine ,
What do you guys think Thanks all for the help pete
Post by marrcel on May 1, 2020 19:36:14 GMT 1
Well there are a lot of procedures how to measure the floath height. With and without gasket and the angle which you hold the carb. Something i check on top of that is that i blow air by mouth with a tube through the floath valve. Well both carbs have to be exactly the same.
