Post by 4l04ever on Apr 18, 2020 21:26:30 GMT 1
Anyone measured the maximum throw at the clutch end?
Mines seems to get between 1.2mm and 1.5mm clearance with the lever fully back, depending how I adjust everything up??
Post by muttsnuts on Apr 19, 2020 11:11:46 GMT 1
1.2mm to 1.5mm is what I target (that's approx 0.10mm clearance for each plate - steels and fibres) when setting them up, so I'd say that is correct, if the bike has aftermarket levers on I've had it as low as 0.5mm as you can't get the same leverage/pull as they tend to bind/hit the switch gear before being full pulled, so I always use a stock clutch lever to check them, then if the owner complains its binding/dragging, I just swap the lever, tell them to try it and then wait for them to come back and throw the crap levers in the bin !
