Post by dave1w on Apr 17, 2020 18:00:22 GMT 1
Just got my crank back from Grampians freshly rebuilt. Quick question, are the crank seals they supply good, or should I go for genuine Yam? Cheers Dave
Post by midlifecrisisrd on Apr 17, 2020 18:12:23 GMT 1
I've never used their seals so cannot comment
Usually when they call me and give me the price, I say I don't need seals and they knock £18 off.
One time they called and the price was £320 as the centre pin was the only usable bit 😱
I said I can buy a new crank for that. I don't need seals - £18
Then asked what was wrong with the lab seal - absolutely nothing, I just change them anyway. £20 off the bill for that 😁
Unless I see the seals coming out a Yamaha bag I ain't using them
Post by jessy03 on Apr 17, 2020 18:18:50 GMT 1
The large ones look genuine ARS type however the smaller ones are SFK I think or similar, I’m with Steve if don’t come out of a Yamaha bag it ain’t going in my bike.
Post by Yogi on Apr 17, 2020 18:23:01 GMT 1
I never buy there seals either The first one they did for me came back with seals on the crank I threw them away and used gen ones
Post by muttsnuts on Apr 17, 2020 20:11:57 GMT 1
I've not used them, but I've had a good look at them and they have the teflon coating on the lips of the seals and look good, much better than shambits ones anyway
I am half tempted to try a set (got a good few here - approx 50 pairs !) and see how they fair, all my customers ask for Yamaha seals, but I am going to try a set in one of my test engines I think to see how they go
Post by doohanno1 on Apr 17, 2020 21:01:18 GMT 1
One would hope that a reputable company would not compromise there work by supplying inferior components..
So far so good for the one's i got done from them...
Post by 4l04ever on Apr 17, 2020 21:06:37 GMT 1
I have used a few and they were ARS seals, so same supplier as OEM Yamaha. Not had any issue with them.
Post by JonW on Apr 18, 2020 1:33:16 GMT 1
Simple rule thats easy to follow: only ever use gen yamaha crank seals.
You'll sleep better at night.
Post by chippy348 on Apr 18, 2020 12:02:31 GMT 1
Just got my crank back from Grampians freshly rebuilt. Quick question, are the crank seals they supply good, or should I go for genuine Yam? Cheers Dave What do they say on the side ? If ARS made in Japan same factory as the Yamaha ones SFK not from Japan
Post by muttsnuts on Apr 18, 2020 12:09:01 GMT 1
agree with Paul, the last set I checked the clutch side said ARS, the stator side was something else which escapes me at the moment, I'll check my stash when I get 5 mins
Post by Norbo on Apr 18, 2020 20:31:56 GMT 1
I dont use them but then i get my yam seals from japan 200 at a time so see no point
Post by 4l04ever on Apr 18, 2020 20:38:31 GMT 1
Hi Norbo
Are both your crank seals ARS branded?
