Post by rigga on Apr 14, 2020 22:24:39 GMT 1
Post by shaunthe2nd on Apr 14, 2020 22:40:19 GMT 1
It is nicely stamped to be fair, better than San Yam managed, his were never so well aligned!
Post by 4l04ever on Apr 14, 2020 22:47:56 GMT 1
Someone has been ringing the ding too many times...
Post by steve h on Apr 15, 2020 11:34:08 GMT 1
Excellent base for an expensive hybrid build.............
Post by risolc on Apr 15, 2020 18:55:05 GMT 1
Lovely neat numbers but I know mine are stamped on ‘ribs’ I wouldn’t know but if your capable of filing the ribs off so nicely then your probably OK stamping numbers back on. Just what I can see
Post by rigga on Apr 15, 2020 20:34:36 GMT 1
Only one reason the ribs are missing, and its not aesthetics.
Post by JonW on Apr 16, 2020 1:17:46 GMT 1
So far no one has seen fit to mill the ribs back in after removing the original (stolen) numbers, before putting on rebirth ones. These parts were cheap and I guess no one owned a mill as they were too expensive, but these days mills that will take an engine case are not so expensive so it will come I guess. Luckily the Yamaha font isnt exactly the same as the punches you see on ebay, but if you had a CNC mill you could cut them like OEM I guess :/
Post by milo777 on Apr 16, 2020 2:32:48 GMT 1
So far no one has seen fit to mill the ribs back in after removing the original (stolen) numbers, before putting on rebirth ones. These parts were cheap and I guess no one owned a mill as they were too expensive, but these days mills that will take an engine case are not so expensive so it will come I guess. Luckily the Yamaha font isnt exactly the same as the punches you see on ebay, but if you had a CNC mill you could cut them like OEM I guess :/ HI JonW how are things going I finished my motor up it is sitting in the frame now getting ready to fire it up here soon Have you had a change to work with the rear sets
Post by JonW on Apr 16, 2020 13:35:17 GMT 1
So far no one has seen fit to mill the ribs back in after removing the original (stolen) numbers, before putting on rebirth ones. These parts were cheap and I guess no one owned a mill as they were too expensive, but these days mills that will take an engine case are not so expensive so it will come I guess. Luckily the Yamaha font isnt exactly the same as the punches you see on ebay, but if you had a CNC mill you could cut them like OEM I guess :/ HI JonW how are things going I finished my motor up it is sitting in the frame now getting ready to fire it up here soon Have you had a change to work with the rear sets No not yet Larry, that bike is a few projects away yet. Keep posting about your build, its gonna be great mate. Put up some pics of the progress when you get a chance.
