Post by malfunction on Apr 12, 2020 12:30:02 GMT 1
Me again from Straya, when I recently purchased this bike the PO had a Unifilter sticker across the front guard very close to the fork brace. On closer inspection I realised the fork brace was a dodgy bros. special. Not being a real sticker fan I removed the Unifilter sticker after I got the bike home and found this www.flickr.com/photos/187911830@N04/shares/4GUj94The PO had make his own fork brace, then overtightened the mounting screws and cracked the guard - then hidden it behind the Unifilter sticker!!! I had tried to be diligent on inspection but some people are just dodgy.
Post by 4l04ever on Apr 12, 2020 13:40:40 GMT 1
At least it looks repairable, but not good that it was not disclosed by the seller.
Post by malfunction on Apr 12, 2020 22:24:48 GMT 1
Hi 4l04ever, the repair part is disappointing - the lack of honesty is more so.
Having just purchased this "totally rebuilt" bike it is VERY disappointing the PO was so deceptive.
There should at least be honour amongst fellow bikers.
Regards,
Mal
Post by jon on Apr 13, 2020 10:05:30 GMT 1
I reason if you bin that brace and replace with a proper on the cracks might not show so prominently.
The curve of the guard and the flat plate have caused the stress.
A bit of glue on the underside of them may help to stop them propagating.
Post by malfunction on Apr 13, 2020 11:17:35 GMT 1
Hi Jon, thank you for your advice. I still haven't yet decided how to fix this problem - but replacing the home made brace will be the first step. Regards, Mal
Post by marsbar350 on Apr 13, 2020 11:44:52 GMT 1
had the same problem with the cracks.i drilled the cracks out with a 3mm drill bit spacing the holes by about 2mm and filled with chemical meatal sanded down and repainted
Post by LC_BOTT on Apr 13, 2020 20:50:33 GMT 1
PM sent
Post by malfunction on Apr 13, 2020 21:49:18 GMT 1
Thanks again to everyone who has responded. Regards, Mal
