Post by Gunny on Mar 4, 2020 20:49:22 GMT 1
Post by Gunny on Mar 5, 2020 21:00:03 GMT 1
Thats a no then, dont suppose anyone knows the sizes either or if these fit. Do you have to change the metal tube or can you just change the bushes
Post by midlifecrisisrd on Mar 5, 2020 21:54:58 GMT 1
They have a lot of sales and feedback is 100% so if they say they fit I'd trust them
Usually the softer bushes wear more so you may get away with that
You will know when you look at it
Post by 4l04ever on Mar 5, 2020 23:10:03 GMT 1
Norbo sells some, as he borrowed an original one from me many years ago to get the measurements
Post by Gunny on Mar 6, 2020 0:20:47 GMT 1
Out of stock at the moment
Post by steeley on Mar 6, 2020 6:06:00 GMT 1
Hi , i will measure one up later today . They are a pair i had made over 20 odd years ago from ali bronze, i think the bore is a little worn but rest of measurements should be ok .
Post by Gunny on Mar 6, 2020 9:36:33 GMT 1
Hi , i will measure one up later today . They are a pair i had made over 20 odd years ago from ali bronze, i think the bore is a little worn but rest of measurements should be ok . Thanks bUd
Post by steeley on Mar 6, 2020 11:56:29 GMT 1
Length 40mm top hat section 34mm x 2.5mm width 28mm bore 22mm hope this makes sense .
Post by wangwang on Mar 6, 2020 14:04:14 GMT 1
I've fitted some
Post by Gunny on Mar 6, 2020 16:12:21 GMT 1
Length 40mm top hat section 34mm x 2.5mm width 28mm bore 22mm hope this makes sense . Thanks Pal, seems to match the ones in the ad
Post by Gunny on Mar 6, 2020 16:12:43 GMT 1
Of those ones from Germany ?
Post by wangwang on Mar 6, 2020 22:46:38 GMT 1
Of those ones from Germany ? The ones on the link, yes.
