Post by stusco on Mar 4, 2020 16:54:52 GMT 1
My latest problem with my RG is it would only run on cylinders 2 and 3 which is the left bank ,so it had to be fuel it turns out my very expensive ceramic ball type needle valves stick closed which doesn’t allow any fuel into the carbs to free the ball I had to push the ball off the seat with a small Allen key but it sticks every time and I can’t blow through it .anyone had this ?
Post by marrcel on Mar 4, 2020 18:19:46 GMT 1
What material is the seat? Picture?
Post by stusco on Mar 4, 2020 18:43:07 GMT 1
Post by tacky1 on Mar 4, 2020 19:05:19 GMT 1
They look like Dents valve, his has the black ball in it, I would call him and get him to swap it out, They are not cheap!!
Post by stusco on Mar 4, 2020 19:16:57 GMT 1
I’ve have text him but know reply yet
Post by stusco on Mar 4, 2020 19:18:31 GMT 1
I’ve had it in warm soapy water and it’s fine now ,so much for high flow and not leaning out on full chat
Post by marrcel on Mar 5, 2020 10:36:01 GMT 1
The non return valves of oil pump are also sensitive. Sometimes they do not close good enough. Cleaning the seat resolves this. In your case the seat is probably brass. With some valve paste or tooth paste you can slightly smoothing the seat. With some heat glue you can stick an dremel axle to it.
Post by stusco on Mar 5, 2020 16:14:43 GMT 1
You can’t remove the balls to access the seat
Post by bare on Mar 5, 2020 20:06:52 GMT 1
Often 'new and improved' isn't despite brochure babbles. Life 101 :-) With ordinary stoopid Valves one can reform (rehabilitate) the valve seat by tapping on the steel ball with a drift.. deforming the brass seat edges into a decent sealing surface. Too easy tho.
Post by tacky1 on Mar 5, 2020 23:41:32 GMT 1
Often 'new and improved' isn't despite brochure babbles. Life 101 :-) With ordinary stoopid Valves one can reform (rehabilitate) the valve seat by tapping on the steel ball with a drift.. deforming the brass seat edges into a decent sealing surface. Too easy tho. On a normal bike you can do this, On the b*****d RG carbs this doesn't work, They are a b*****d to seal, Even new genuine ones leak in a few weeks,
