Post by jon on Feb 26, 2020 19:36:18 GMT 1
I know it’s more complicated maths than I’m asking, but as a rough guide what does say 5mm of increased ride height equate to at the wheel spindle?
Post by midlifecrisisrd on Feb 26, 2020 19:51:01 GMT 1
Think it's about an inch
Post by jon on Feb 26, 2020 20:22:03 GMT 1
I’m thinking maybe a 160/70 tyre as opposed to a 160/60 will also give me another 16mm.
Post by midlifecrisisrd on Feb 26, 2020 21:00:46 GMT 1
I’m thinking maybe a 160/70 tyre as opposed to a 160/60 will also give me another 16mm. Jon What bike are we talking? Lc or ypvs? Steve
Post by jon on Feb 27, 2020 8:12:11 GMT 1
Sorry, should have said, it makes all the difference to the original question maybe.
It’s a spread LC.
Post by midlifecrisisrd on Feb 27, 2020 9:27:31 GMT 1
Ok
As a rough calculation if you measure the distance from the pivot to the shock mount and the pivot to the rear spindle then look at the ratio between them you can calculate the height difference
As in if it is 3 times greater your 5mm equates to 15mm ride height change
Post by jon on Feb 27, 2020 19:20:37 GMT 1
Ok As a rough calculation if you measure the distance from the pivot to the shock mount and the pivot to the rear spindle then look at the ratio between them you can calculate the height difference As in if it is 3 times greater your 5mm equates to 15mm ride height change Steve Thanks Steve, Sounds logical. Has anyone got a picture of a 160/70/17” tyre fitted. Does it look too balloon like? Seems to be on more touring models for extra comfort maybe? Jon
Post by jon on Mar 1, 2020 17:24:04 GMT 1
I’ve had another look today, and I’m not happy.
While my current LC hybrid has slightly more rear ride height than a standard LC it’s nowhere near my first LC hybrid. I’m 6’4” so the ride height is important .
I’ve heard an RD125LC shock is 25mm longer? But can’t find a YSS one.
Does anyone know the length centre to centre of an 350LC and 125LC shock?
I will be phoning Nitron tomorrow to see if they can rebuild my unit longer.
