Post by mak595 on Feb 19, 2020 19:17:43 GMT 1
Guys, can you use 350LC selector forks in a ypvs motor?
Post by tony1964 on Feb 19, 2020 20:35:15 GMT 1
Guys, can you use 350LC selector forks in a ypvs motor? The fowlers part numbers are the same so they should be ok. may be worth double checking the numbers yourself though. Theses numbers replace the original part number. 2 x 2GU1851100 1 x 2GU1851200 Tony
Post by dusty350 on Feb 19, 2020 20:36:42 GMT 1
Yep, the selector forks in a Pv are a 4l0 part number, so are the same Dusty
Post by dusty350 on Feb 19, 2020 20:38:52 GMT 1
Beat me to it Tony My fiche shows a 4l0 part number which is then superceded by the numbers you have listed, so they are good for both bikes Dusty
Post by mak595 on Feb 20, 2020 0:44:59 GMT 1
Thanks Guys
