Post by JonW on Feb 19, 2020 2:02:35 GMT 1
Ive just realised I may well not have the right spacer for the LC2... Does anyone have a measurement for this so I can check? ta.
(I think what I have here are F1, but I could be wrong lol)
Post by midlifecrisisrd on Feb 19, 2020 9:13:29 GMT 1
As far as i knew they were the same
Inner swing arm dimension was the same. Just the spindle was longer to go through the box section arm
Post by Deleted on Feb 19, 2020 9:53:04 GMT 1
I thought so myself, the spacers are the same part number,
Interestingly however the swing arm inside dimensions are different F1 is actually narrower than LC2, 212mm as opposed to 220mm
At least on the two spares I have that I'm comparing to
Post by JonW on Feb 19, 2020 12:10:55 GMT 1
I make the LC2 part no. 90387-157A2
And the F1/F2 is 90387-156L5
I cant find any fiche where the are the same pat number?
Post by Deleted on Feb 19, 2020 12:18:35 GMT 1
Hi Jon
Looks like it was superseded to the 157A2 so the same I'd say
COLLAR Not Available 90387-157A2-00
from Partzilla RZ350N 1985 Rear wheel item 24
COLLAR 90387-157A2 Replaces 90387-156L5
From Fowlers RD350LC 57V 1985 item 25
Post by JonW on Feb 19, 2020 12:20:53 GMT 1
Ahha! Ok, thats great. Thanks Howard. Just got to locate one in my stash of zinc'd parts and Im golden, fingers crossed
Post by Deleted on Feb 20, 2020 15:42:11 GMT 1
Hi Jon
Did you end up finding one?
I've found a spare that hasn't been plated, haven't got into my box of plated parts yet
Post by JonW on Feb 20, 2020 22:17:09 GMT 1
I'm going to look today Howard, I'll report back
Post by Deleted on Feb 21, 2020 3:59:38 GMT 1
I've got a spare plated one, well actually 2
Just in case
Post by rich on Feb 21, 2020 9:15:39 GMT 1
I thought so myself, the spacers are the same part number, Interestingly however the swing arm inside dimensions are different F1 is actually narrower than LC2, 212mm as opposed to 220mm At least on the two spares I have that I'm comparing to LC2 is slightly wider due to the thickness of the external chain adjusters. F1 obviously has internal adjusters in the box section.
Post by Deleted on Feb 21, 2020 14:06:36 GMT 1
Good point Rich
TBH I never considered that the chain adjusters wrapped around the swing arm ends
So 4mm per side is about right
I thought for a while I had a dud arm
Post by JonW on Feb 21, 2020 23:07:48 GMT 1
I've got a spare plated one, well actually 2 Just in case Thanks Howard, Ive still not been able to check, flat out on other things at the mo.
