Post by scooter on Jan 9, 2020 15:55:54 GMT 1
Hi all is it best to put the grey joint compound on both sides of the base gaskets when reinstalling the cylinders
Post by midlifecrisisrd on Jan 9, 2020 16:44:17 GMT 1
Personally I fit them dry
A quality gasket need no sealant
Post by jon on Jan 10, 2020 10:55:43 GMT 1
I fit Yamaha ones dry, and smear grease on paper ones. Both seem to work fine.
antos
Post by antos on Jan 11, 2020 19:57:30 GMT 1
After I blew one I fitted a new yamaha one with a smear of sealant and ok after a years running👍
Post by yamman1066 on Jan 11, 2020 20:56:02 GMT 1
hi ,a smear grease allways
Post by 4l04ever on Jan 12, 2020 14:49:47 GMT 1
The smear of grease also greatly helps with removal in the future.
Post by stusco on Jan 12, 2020 16:43:41 GMT 1
I use a smear of clear gasket sealant ,you can reuse the clutch casing gasket if you do this
