Post by pdxjim on Nov 24, 2019 7:42:40 GMT 1
Search on here says some are left hand thread, and some are held by a set screw.
Bike is an early JDM 4U0.
Knob is sheared off at the shaft. No set screw to be seen. Plenty of meat to grab on and spin clockwise til my arm gets tired, but it appears to be stuck fast.
Any tips?
Post by LC_BOTT on Nov 24, 2019 9:28:55 GMT 1
You have to try and get a small screwdriver down the shaft of the knob (oooeerr) to stop it turning, whilst you turn the trip anti CW as you say. One of mine was a right pain, and so tight I thought I was going to break the speedo. If the clocks are apart, could you cut the plastic off?
Post by Jethro5 on Nov 24, 2019 10:01:19 GMT 1
Could only get mine off after I opened the clock up and held the metal shaft with pliers while turning the knob.
Post by wangwang on Nov 24, 2019 10:09:46 GMT 1
Remove the rubber grommet, if not already removed, you will need a small screwdriver or similar, bent at 90• at the tip, slide it past the remains of the tripknob, and lift to apply pressure on the shaft, that should then let you unscrew the plastic knob.
Post by midlifecrisisrd on Nov 24, 2019 11:57:53 GMT 1
Is it not a reverse thread so you are actually tightening it when resetting
Post by stusco on Nov 24, 2019 12:01:26 GMT 1
Left hand thread on a lc👍
