Post by pdxjim on Nov 10, 2019 7:29:34 GMT 1
Search function led me on a few wild goose chases, but no definitive answer ...
What's the ideal master cylinder size for pumping two blue spot calipers?
My standard 4U0 master is in pretty sad shape and will likely need a re-sleeve to seal properly, so hoping to just use the one off my TDR250 as I went to a 12mm on the TDR when I fitted a single blue spot.
The TDR master is, I believe, 16mm or 5/8".
So, will this be about right, or should I be looking for a different size (or rebuild the 4U0 one)?
Post by 84rzrider on Nov 10, 2019 8:29:08 GMT 1
Jim, On my RZ I used an R1 remote reservoir master cylinder from the same era as the blue dot calipers. 98 - 02 if memory serves. It was cheap like $50 on eBay. I had to make a little sub harness to hook up the brake light. Mine didn't come with the reservoir bracket so I spaced it out with a long bolt from the master cylinder mount. Works perfect. I was able to use the steel braided lines that attached to the RZ calipers originally and had to dig up a single banjo bolt at the master cylinder as the R1 master cylinder had a double banjo feeding 2 lines.
Post by ianboom on Nov 10, 2019 8:33:14 GMT 1
There are lots of master cylinders that will work, anything that uses blue spot type calipers. R1, R6, Xjr1300, mt09 etc. I have the bore size somewhere. 14mm according to my notes!
Post by pdxjim on Nov 10, 2019 8:37:06 GMT 1
There are lots of master cylinders that will work, anything that uses blue spot type calipers. R1, R6, Xjr1300, mt09 etc. I have the bore size somewhere. Bore size would be helpful, as I'm trying to maintain stock(ish) appearance and the remote res MC's are too modern looking for this bike. ... and using what I've got laying about means I can spend the money on something else.
Post by ianboom on Nov 10, 2019 8:47:00 GMT 1
14mm according to what I have written down, but it would be worth a Google!
dezcbr
Post by dezcbr on Nov 10, 2019 11:12:58 GMT 1
Try a MT07 or 09 brembo master cylinder. Rectangular reservoir with bonus of a mirror mount
Post by midlifecrisisrd on Nov 10, 2019 11:36:19 GMT 1
Mt07/09 is what I've used on the last few hybrids
Same style as of but brembo and think they are 16mm
Post by 4l04ever on Nov 10, 2019 11:45:55 GMT 1
Your TDR250 front master cylinder is 14mm, and looks standard, so worth a go if you already have it.
Post by 4l04ever on Nov 10, 2019 11:48:07 GMT 1
I used a YBR125 front master cylinder (11mm bore) on my LC with a single blue spot, as the 1/2" LC250 one was too wooden. YBR125 master cylinder takes standard LC levers as does the TDR250 one.
Post by ringding on Nov 10, 2019 12:49:34 GMT 1
I used a YBR125 front master cylinder (11mm bore) on my LC with a single blue spot, as the 1/2" LC250 one was too wooden. YBR125 master cylinder takes standard LC levers as does the TDR250 one. What 4L04ever says. I found the standard TDR M/C with a blue spot caliper incredibly wooden, no feel at all. With a 11mm M/C it is so much better. I think I used one off a WR125X, as that was what was available cheaply at the time.
Post by Deleted on Nov 10, 2019 13:06:44 GMT 1
I found this on Ducati.ms forum
I hope it's of some help as it seems to explain it quite succinctly
QUOTE
The main reason (other than for appearance and weight savings) that Ducati owners replace the factory set-up with a radial aftermarket unit is to obtain a different MC piston size (hydraulic ratio) and lever pivot point distance (mechanical ratio.) This allows you to selectively increase or decrease the amount of pull force required to develop the same force at the brake pads by using a larger or smaller MC piston diameter. This combined with a shorter or longer distance between the lever pivot point and the piston actuation link will shift the control to one of more power, or more sensitivity if you prefer.
Keep in mind however, changing your stock master cylinder to an aftermarket radial design will NOT give you more braking power to help you stop sooner.
A radial master cylinder with a different piston diameter and/or lever fulcrum-to-piston distance will only change the feel of the brakes at the lever. So keep in mind that Ducati chose a master cylinder size to give you the best modulation characteristics (feel, sensitivity and control) for your bike.
Good modulation means good feedback to the rider during a stop. A good braking system needs to establish the closest linear relationship possible between the force applied to the brake lever and the actual deceleration of the bike. Stopping power is technically easy to achieve, but achieving it along with good proportional braking response is more difficult. This, I feel, is the major factor influencing braking quality.
That’s not to say that the Ducati engineering department’s choice is best for all riders or riding conditions. The best choice for the track isn’t the best choice for the street.
Different riders have different preferences and we’re all adaptable. A rider is able to compensate for one performance drawback to gain an advantage with another. But again, it's situational dependent; a braking system that gives repeated stops from 150mph with the force application of one finger is not necessarily optimum for a 40mph panic stop in traffic. Even though a rider is adaptive to a braking system's general behavior doesn't mean that in an emergency that he'll use a light one-finger pull to stop.
So let’s move on to your choices.
First, there’s a different master cylinder size requirement for single rotor systems than for dual rotor systems. A dual rotor set-up has a lot more caliper pistons to move so a larger volume of hydraulic fluid has to be moved by the master cylinder piston.
Also, since different Ducati models have different size calipers and rotors you can’t always translate a recommended master cylinder size to another setup.
A master cylinder size designation is written AAxBB where AA is the diameter of the piston in mm, BB is the fulcrum-to-piston distance in mm.
The master cylinder piston diameter is chosen based on the number and size of the caliper pistons.
A fulcrum-to-piston distance affects two things: the amount of force needed at the lever, and the distance that the lever needs to be pulled through (to displace and compress the same amount of hydraulic fluid which in turns forces the caliper pistons against the rotor discs) to yield the SAME stopping power.
Single Disc
The Brembo aftermarket radial 16mm diameter master cylinders offer you the choice of a brake lever fulcrum-to-piston distance of either 16mm or 18mm. The stock Brembo lever has a 16mm dimension.
So your choice is either 16x16 or 16x18.
From the geometry, a 18mm lever will need to be pulled a 11% shorter distance than a 16mm lever but will at the same time require more lever force than a 16mm to stop the same distance.
Dual Disc
The Brembo aftermarket radial 19mm diameter master cylinders offer you the choice of a brake lever fulcrum-to-piston distance of either 16mm, 18mm or 20mm. The stock lever is 16mm.
So your choice is either 19x16, 19x18 or 19x20.
19x16 (stock) requires the least less lever effort but the longest pull distance.
19x18 requires 11% lighter pull and 11% longer pull distance than the 19x20 MC. More feel (better modulation characteristics) than the 19x20
19x20 requires the most lever force but the shortest pull. More like a trigger action.
Some riders think that this short-pull trigger action means that they have "better" brakes, but they don't - at least not for all riding conditions. What they do get is the same braking power with poorer modulation (feel) characteristics. Good for the track perhaps, but often dangerous on the street, especially in the wet. In an emergency, most of us have the instinct to grab a brake hard. So if you value a better feel, when choosing between the 19x18 and the 19x20 for the street, go for the 19X18. Better still stay with Ducati’s choice, 19x16.
On the other hand, some prefer their lever hard.
So again, I'm not suggesting that every rider will have the same preference in a braking system's modulation characteristics. Depending on your preference (or need) you can have brakes with an initial vague feeling, a strong initial bite, or something in between. You can select pads that have better high temperature behavior. On a race bike you can select brake pad and rotor material that will survive a race without needing replacement, but on the street, materials need to be more durable and function under less severe braking conditions and more varied weather conditions.
UNQUOTE
Post by marrcel on Nov 11, 2019 16:57:55 GMT 1
I use the blue spots with fazer1000 mastercylinder. Always a clear feeling
