Post by hondasp1 on Oct 13, 2019 9:15:04 GMT 1
anyone around the pontefract area with a ypvs kickstart i could try on my lc ?
Post by oldelsieboy on Oct 13, 2019 9:19:14 GMT 1
anyone around the pontefract area with a ypvs kickstart i could try on my lc ? Why?
Post by hondasp1 on Oct 13, 2019 9:26:42 GMT 1
put some tarozzi rear sets on and the kickstark catches on the brake pedal
Post by hondasp1 on Oct 13, 2019 9:28:24 GMT 1
the ypvs kickstart looks to have a different profile
Post by jon on Oct 13, 2019 9:37:50 GMT 1
I thought they were the same apart from the raised 29L boss on th YPVS ones?
Maybe yours is one spline anti-clockwise out?
Post by hondasp1 on Oct 13, 2019 11:11:50 GMT 1
what other kickstart are people using with torossi rear sets to solve the problem of hitting the rear brake lever
Post by stusco on Oct 13, 2019 11:27:56 GMT 1
I altered the rearset so the brake pedal flipped up out of the way ,I have a short kickstart fitted ,I have now went back to standards pegs and hangers
Post by hondasp1 on Oct 13, 2019 11:31:12 GMT 1
any pictures
Post by stusco on Oct 13, 2019 11:37:11 GMT 1
I only have one picture but not of the mod ,I’ll see if I can find the article I got it from
Post by JonW on Oct 13, 2019 12:45:03 GMT 1
I know a local chap Arron did that mod to his Tarozzis, pretty easy to do from what he said.
Post by stusco on Oct 13, 2019 13:43:17 GMT 1
This is where I found the solution www.rzrd500.com/phpBB2/viewtopic.php?t=7365sorry link doesn’t work what i did was I slotted between a couple of the holes so the pin that adjusts the height can run round and move the brake lever out of the way
Post by markhoopy on Oct 13, 2019 23:48:48 GMT 1
Not sure whether this might help or not but I had a TZR250 3MA kickstart on my 350N. Shorter than standard and doesn't stick out as far when you spin it out to start the bike. I should have a 350 YPVS kickstart somewhere too but as already mentioned they are the same as a standard 250/350 LC one.
Post by JonW on Oct 14, 2019 0:28:32 GMT 1
Post by stusco on Oct 14, 2019 7:10:49 GMT 1
That’s where I got it👍
Post by JonW on Oct 14, 2019 8:07:12 GMT 1
yes, i was just making a working link for you
Post by steeley on Oct 14, 2019 8:14:36 GMT 1
Hi , had this when i fitted my rear sets . All i did was put an angle on the brake peddle so the kick start cleared it.
