Post by headcoats on Sept 22, 2019 10:03:19 GMT 1
I realise I have dropped a bollock with my front right spacer on my RGV forks with KR1S wheels :-(
I have the O.D. too wide so the right fork doesn't "adjust" when you bounce the forks !
It may be OK but don't want anything binding, they do seem to move freely though
So has anyone got the spec of the spacer please ?
Post by headcoats on Oct 1, 2019 11:43:37 GMT 1
Anyone LC Crew :-)
Post by morgy on Oct 1, 2019 14:48:58 GMT 1
Mine is loosely fitted for now... I might be able to post up some dimensions when i get to work on the bike again..
Post by headcoats on Oct 1, 2019 16:57:43 GMT 1
And Pics please if possible :-)
Post by morgy on Oct 1, 2019 18:36:42 GMT 1
Will do it tomorrow for you mate..
rhrc
Post by rhrc on Oct 2, 2019 12:04:38 GMT 1
I could do with this also as I need to make one
Post by LC_BOTT on Oct 2, 2019 12:44:41 GMT 1
Post by muttsnuts on Oct 2, 2019 20:37:06 GMT 1
Front wheel R/H side
OD 23mm
ID 17mm
Flange OD 39.3mm
Flange thickness 3.1mm
Total length 32mm
Note there is a step to the flange of 0.6mm
Rear wheel Right to left
OD 34mm
ID 26.75
Total length 20.4mm
Reduced section
ID 20mm, 5.25mm thick
Inner hub spacer
OD 30mm
ID 20mm
Total length 50mm
Reduced shoulder 25mm (fits inside the hub bearing)
Reduced shoulder length 13.25mm
Left spacer
OD 28mm
ID 20mm
Total length 20mm
Flange OD 38mm
Post by headcoats on Oct 2, 2019 20:40:41 GMT 1
Cheers All :-)
Looks like I need to get the OD down to 23mm on the spacer , oops!
It's only done a lap of the garage though
Post by headcoats on Oct 3, 2019 12:08:55 GMT 1
OD 23mm
ID 17mm
Flange OD 39.3mm
Total length 32mm
Got the spacer out now
Now on the above spec the OD is 23mm, so does that mean the thick part of the axle is the same on the right side ?
I have a stainless front spindle from an unknown source I bought years a go from fleabay and the OD of the thickest part of the spindle is 21.70mm It goes in the right fork and tightens up tight with the pinch bolts but does the right spacer have to be exactly the same OD as the spindle so when the right leg "floats" , it can move slightly in and out smoothly ?
Post by headcoats on May 17, 2020 9:21:00 GMT 1
Does anyone have the dimensions for the RGV250 VJ22 front wheel spindle please
Possibly getting one made in stainless
Also the thread size and pitch etc
Post by headcoats on Feb 7, 2021 23:26:03 GMT 1
Back on this baby !
Post by LC_BOTT on Feb 8, 2021 9:56:19 GMT 1
Post by headcoats on Feb 8, 2021 10:04:05 GMT 1
There is a bloke on fleabay making stainless spindles for a reasonable cost but need dimensions as I haven't a spare one to send him
There is a titanium one by Titan classics for £150 !
