Post by grim on Feb 18, 2017 19:18:06 GMT 1
Hi
Does anyone have the dimensions for front and rear rgv250 vj22 wheel spacers so that I can turn some. Thanks Graham
Post by grim on Feb 20, 2017 21:54:23 GMT 1
anyone got any laying about that they can measure ?
Post by yamark on Feb 22, 2017 7:56:45 GMT 1
anyone got any laying about that they can measure ? Hi Graham, how quickly do you need these measurements? My bike runs VJ22 front and rear, but is mocked up and nearly ready for a complete strip down.
Let me know what dimensions you need, and I'll see what I can do.
Cheers Mark
Post by grim on Feb 22, 2017 11:47:25 GMT 1
Hi Mark I bought my parts separately and have no wheel spacers at all so any measurements you could give me would be great, I'm not in a desperate hurry for them. Thanks Graham
Post by dusty350 on Feb 22, 2017 14:36:15 GMT 1
Hi You can buy ally spacer kits for these. I think it's Tyga that do them. Dusty
Post by dusty350 on Feb 22, 2017 14:38:43 GMT 1
Post by grim on Feb 22, 2017 21:43:53 GMT 1
Thanks Dusty but I would prefer to turn them myself if possible as I have the ally and can save the money towards other parts. Graham
Post by dusty350 on Feb 22, 2017 22:25:29 GMT 1
Hi If you turn a few sets up I'm sure you'll shift them on here. Lots of guys use the Rgv parts - only 1 of mine has the ally spacers, the others are steel Dusty
Post by yamark on Mar 12, 2017 16:06:45 GMT 1
Hi Does anyone have the dimensions for front and rear rgv250 vj22 wheel spacers so that I can turn some. Thanks Graham Hi Graham, RGV250 VJ22 spacers.
Front wheel R/H side OD 23mm ID 17mm Flange OD 39.3mm Flange thickness 3.1mm Total length 32mm Note there is a step to the flange of 0.6mm
Rear wheel Right to left OD 34mm ID 26.75 Total length 20.4mm Reduced section ID 20mm, 5.25mm thick
Inner hub spacer OD 30mm ID 20mm Total length 50mm Reduced shoulder 25mm (fits inside the hub bearing) Reduced shoulder length 13.25mm
Left spacer OD 28mm ID 20mm Total length 20mm Flange OD 38mm Flange thickness 3.1mm
I don't have the size of the spacer between the wheel bearings on both wheels. (I've already fitted new wheel bearings/seals so cant remove them)
I'll post up a picture later (as I be on Photobollox), and my measurements should make sense.
Cheers Mark
Post by yamark on Mar 12, 2017 17:41:07 GMT 1
Hi Graham, Images of the spacers. Left is the front wheel spacer, Then the rear wheel as they are on the bike looking forward.
HTH Kind Regards Mark
Let me know if you need more info
Post by yamark on Mar 12, 2017 20:47:12 GMT 1
And the second image that I couldn't load earlier
Post by grim on Mar 12, 2017 21:16:55 GMT 1
That's great Mark, Thanks very much for taking the time to measure them, I will be replacing the bearings in my wheels so I can measure the bearing spacers then. Graham
