Post by headcoats on Sept 17, 2019 15:16:33 GMT 1
I have an F2 stator I think but some of the copper wire has got crushed on one arm and a wire snapped on one more
Does this mean a re wire job or could repairs be done just to the damaged areas? Got another with no plugs too Do the White wires have to go in a precise order ?
Post by midlifecrisisrd on Sept 17, 2019 16:41:33 GMT 1
White wires go anywhere
I'd use the one with no plugs
Crushed winding ain't good
Post by Shytalk on Sept 18, 2019 10:17:44 GMT 1
You can meter them to check resistance, but if they’re open circuit or short even then it’s a rewind, not realistic to attempt to do a minor repair. I have got a good stator with all the plugs too..........you’ll have to sell some more CDs though 😉
Post by headcoats on Sept 18, 2019 11:46:04 GMT 1
Cheers :-)
The one stack has just one broken wire but the other has several crushed wires on the surface
I reckon someone with a flywheel holding tool (with the nut and bolts you adjust for length) had em too long :-(
