Post by peter007 on Sept 4, 2019 21:13:30 GMT 1
Hi guys has anyone had experience of powder coating parts with rubber bushes fitted ? I’m restoring a Suzuki X7 and the frame has 6 rubber bushes for footrest and exhaust mounts . I’ve tried to remove them but they’re totally solid . ☹️ My question is will they melt int the powder coasters oven ? Thanks for any advice guys cheers pete 👍
Post by russpuss on Sept 4, 2019 21:38:30 GMT 1
I’d guess they’d melt, I’ve restored 3 X7’s, I blowtorch the rubbers then use a dremmel to cut a slit in them and then knock out.
Post by shaunthe2nd on Sept 5, 2019 7:51:05 GMT 1
Not sure the oven would be hot enough to melt them, but likley to cause a bit of a mess, during sand blasting and baking process. Not done an X7 but i would always strip the frame of all parts totally before sending to powder coaters.
I usually gently heat any rubbers using hot air gun to help remove them. Not had to burn them out yet as russpuss suggests but that is of course a suggestion for the stubborn ones.
Post by russpuss on Sept 5, 2019 8:07:32 GMT 1
There’s 4 in the frame for the exhausts and 2 in each footpeg making 8 total. The rubber bush is inside a very slim metal bush. I believe the oven goes to 400C, my coater always tells me to take them out, hence the burning and slitting of the outer slim metal bush, I have a 25t press that I tried but it rips the rubber out leaving you to slit the metal still. Why not send the footpegs for blast and coat 1st with them in to see what happens?
Post by Shytalk on Sept 5, 2019 14:04:16 GMT 1
My question is will they melt int the powder coasters oven ? Thanks for any advice guys cheers pete 👍 YES they will melt in a powder coating oven. As said best cut them out before sending for blasting and coating.
Post by JonW on Sept 5, 2019 14:09:07 GMT 1
Defo remove them as has been said.
Post by tell7437 on Sept 6, 2019 23:01:10 GMT 1
Another option is get the frame painted, which looks far better in my opinion
Post by peter007 on Nov 21, 2019 19:17:34 GMT 1
There’s 4 in the frame for the exhausts and 2 in each footpeg making 8 total. The rubber bush is inside a very slim metal bush. I believe the oven goes to 400C, my coater always tells me to take them out, hence the burning and slitting of the outer slim metal bush, I have a 25t press that I tried but it rips the rubber out leaving you to slit the metal still. Why not send the footpegs for blast and coat 1st with them in to see what happens? well i took a chance on the bushes in the frame i put a bolt thru all of them with a large washer each side so as to make the rubber captive in its socket/bush ,thinking if they melt well so be it ill have to drill them out . had the footage blasted by powder guy ( very helpful and understanding ) and then sprayed them myself , thinking ill at least save 4 bushes at around £8 each . and wahey !!! the trick with the bushes worked !!! they did melt ever so slightly but are absolutely fine so great result , hope this helps other guys , cheers Pete
