Post by perazzi350 on Dec 30, 2019 8:20:16 GMT 1
Ok, don’t laugh😂 , it was a cut down milk carton and painted with vinyl paint, as soon as it moved the paint come off ! I have been watching them on fleabay to much money IMO so still I’m still looking for one.
Post by perazzi350 on Jan 13, 2020 20:36:06 GMT 1
Post by veg on Jan 13, 2020 20:40:17 GMT 1
Got to ask what rear reservoir have you used? if it is a hrc type tube make sure the tube doesn't end up being hydroscopic, the last 2 i have had i had to replace the hose because of it and they were bought from reputable suppliers.
Post by perazzi350 on Jan 13, 2020 20:40:59 GMT 1
I took the sound advise from the people on here who know far more than my little bit and stripped the whole bike and now feel quite satisfied that it will be safe now... not so sure about the old dodgy rider though! 😜😜
Post by perazzi350 on Jan 13, 2020 20:46:57 GMT 1
Got to ask what rear reservoir have you used? if it is a hrc type tube make sure the tube doesn't end up being hydroscopic, the last 2 i have had i had to replace the hose because of it and they were bought from reputable suppliers. I am not sure what reservoir it is, it was on the bike when I got it, thanks for the heads up I will have to monitor it and see how it goes . Steve m
Post by perazzi350 on Jan 13, 2020 20:50:07 GMT 1
Oh and I got a proper coil cover from a forum member so slowly getting there
Post by LC_BOTT on Jan 13, 2020 21:35:05 GMT 1
Doing a fine job so far, one observation though.... have you tried the fork travel (side to side) with a tank fitted, as I'm sure I had to reweld the tabs on the headstock, or move the posts on the bottom yoke to stop the forks hitting the tank?? Might have missed it in an earlier post??
Post by perazzi350 on Jan 13, 2020 21:48:23 GMT 1
Doing a fine job so far, one observation though.... have you tried the fork travel (side to side) with a tank fitted, as I'm sure I had to reweld the tabs on the headstock, or move the posts on the bottom yoke to stop the forks hitting the tank?? Might have missed it in an earlier post?? I have not tried it with the tank as it’s at the painters so I must check this when i get it back thanks for telling me . Steve
Post by perazzi350 on Jan 18, 2020 15:40:00 GMT 1
Post by perazzi350 on Jan 19, 2020 15:28:49 GMT 1
Hi all you people that have RGV front end how have you fitted the twin hooters ? I bought the bracket for the LC can’t see how it will fit and how, do you make your own from the bottom yolk? Any advise please
Post by headcoats on Jan 19, 2020 16:33:17 GMT 1
Have a look b my Better Late Than Never build thread I made a bracket that bolted underneath
Post by perazzi350 on Jan 19, 2020 16:42:26 GMT 1
Have a look b my Better Late Than Never build thread I made a bracket that bolted underneath Ok thanks👍
Post by headcoats on Jan 19, 2020 16:44:29 GMT 1
Bottom of page 3
Post by mouse on Jan 19, 2020 18:54:15 GMT 1
Hi all you people that have RGV front end how have you fitted the twin hooters ? I bought the bracket for the LC can’t see how it will fit and how, do you make your own from the bottom yolk? Any advise please On mine the bottom yoke (RGV) was drilled and tapped to to take the two bolts to accept the LC bracket Mouse
Post by perazzi350 on Jan 19, 2020 20:27:56 GMT 1
Hi all you people that have RGV front end how have you fitted the twin hooters ? I bought the bracket for the LC can’t see how it will fit and how, do you make your own from the bottom yolk? Any advise please On mine the bottom yoke (RGV) was drilled and tapped to to take the two bolts to accept the LC bracket Mouse Cheers Mouse now I have a couple of options. Steve
Post by perazzi350 on Feb 8, 2020 14:51:55 GMT 1
Hi all fitted a new cringe chain the thinnest one I could get when I fitted I still had real trouble clearing the rear tyre so I took a gamble and bought a new sprocket carrier this one is thicker so assume the old one had been machined down for some reason now at last all is good.
Post by perazzi350 on Feb 8, 2020 14:58:14 GMT 1
Post by perazzi350 on Feb 22, 2020 15:11:41 GMT 1
Post by perazzi350 on Feb 23, 2020 8:54:24 GMT 1
Anyone know if this tail unit is fitted right if not any info or pics on how it should go . Steve
Post by perazzi350 on Feb 23, 2020 8:55:27 GMT 1
Post by 4l04ever on Feb 24, 2020 22:38:34 GMT 1
Is that a nice Dom Perignon cork in the overflow bottle? :-)
Post by perazzi350 on Feb 24, 2020 23:19:32 GMT 1
LOL... I took it off to clean it and could not find it so stuck the cork in it just to stop any crap getting in, I saw it myself and wondered if anyone would ask if it was for sale ! found proper one again now
Post by perazzi350 on Mar 7, 2020 14:16:58 GMT 1
Post by tipfinchy on Mar 7, 2020 14:42:08 GMT 1
clocks look good , out of interest what year and model are the calipers off mart
Post by perazzi350 on Mar 7, 2020 16:55:26 GMT 1
clocks look good , out of interest what year and model are the calipers off mart Hi Mart they are off 1996 600 srad gsxr Steve
Post by perazzi350 on Mar 7, 2020 17:00:16 GMT 1
Post by veg on Mar 8, 2020 10:14:00 GMT 1
Have you tried your side stand yet? Rear sets and the standard side stand generally don’t mix, the stand interferes with the gear change. Had loads of problems with mine and it still isn’t right. Clocks look good I fitted koso clocks into std cases.
Post by perazzi350 on Mar 8, 2020 13:52:38 GMT 1
Have you tried your side stand yet? Rear sets and the standard side stand generally don’t mix, the stand interferes with the gear change. Had loads of problems with mine and it still isn’t right. Clocks look good I fitted koso clocks into std cases. Hi Veg no I have not tried the stand yet hopefully it will be ok it already had rearsets I changed them for better looking ones so fingers crossed👍
Post by veg on Mar 8, 2020 14:13:53 GMT 1
Mine are Nk and they are notorious for it, hope all goes well as it always seems to be the silly little things that causes the biggest problems
Post by perazzi350 on Mar 8, 2020 14:30:15 GMT 1
Mine are Nk and they are notorious for it, hope all goes well as it always seems to be the silly little things that causes the biggest problems I got my new ones from Norbo so should be OK every time I do something it leads into something more ! Ah the joys of a hybrid 👍
