Post by yamman1066 on Sept 8, 2019 17:54:10 GMT 1
hi ,thats not good at all !! nk racing will do a kit to make it fit fine,good luck
Post by midlifecrisisrd on Sept 8, 2019 17:54:56 GMT 1
Oh Jesus!
There should be a reducing bush bonded into the rgv sleeve to reduce it to the lc spindle diameter
I would not trust anything on that bike now
Post by headcoats on Sept 8, 2019 18:32:39 GMT 1
That is shocking !
To build it like that you must be a f**kwit but to sell it on to someone else is criminal !
Post by donkeychomp on Sept 8, 2019 23:09:54 GMT 1
Surely that's the wrong spindle!
Post by perazzi350 on Sept 20, 2019 20:05:41 GMT 1
Post by perazzi350 on Sept 20, 2019 20:07:58 GMT 1
Spindle looking much happier now with bush now fitted, thanks for telling about N K racing he sorted out what was missing so now all is good 👍
Post by morgy on Sept 21, 2019 7:51:25 GMT 1
Mate strip that bike down and check everything!!!! Who ever put that bike together could miss one simple item like that who knows what else is wrong..
Post by veg on Sept 21, 2019 10:50:57 GMT 1
Agree with morgy I would be going over that with a fine tooth comb, I wouldn’t trust anything on it.
Post by perazzi350 on Sept 21, 2019 15:02:37 GMT 1
yes guys I fully agree with you all, its in bits now spread around the shed LOL even the rear sprocket was not tight on the carrier.
Post by morgy on Sept 21, 2019 15:08:42 GMT 1
Post by veg on Sept 22, 2019 9:57:06 GMT 1
yes guys I fully agree with you all, its in bits now spread around the shed LOL even the rear sprocket was not tight on the carrier. Just goes to show you unless you know and trust the builder or the bike has receipts from a reputable builder always check everything. At least youlll know it’s been done properly.
Post by rigga on Sept 22, 2019 14:10:09 GMT 1
I bet the handling was interesting built as it was.
Post by perazzi350 on Sept 24, 2019 17:14:48 GMT 1
Hi just an update on chain hitting frame/tyre, ok now swinging arm is fitted with spacer and refitted into frame nice and tight all wheel aligned up and looking good, also checked from centre of spindle to wheel spindle both sides. Front sprocket now needs to be smaller by 3mm, this I achieved by laser and fishing line, now have 12.6mm clearance between frame and centre and the same on the tyre to centre
Post by perazzi350 on Sept 24, 2019 17:16:57 GMT 1
Laser from front sprocket as it
Post by perazzi350 on Sept 24, 2019 17:22:29 GMT 1
Hopefully all sorted soon as I spoke to Nigel (no) went through everything and measurements from the sprocket shaft, now have a new spacer coming for ypvs and I think it’s a 9mm offset sprocket coming, 👍
Post by perazzi350 on Sept 24, 2019 17:30:44 GMT 1
Wha said fags are no good for ya🤪
Post by perazzi350 on Sept 24, 2019 17:33:08 GMT 1
Post by perazzi350 on Sept 24, 2019 17:36:29 GMT 1
I didn’t plan on this, thought I’d just get new paint and bar risers LOL, once rear is sorted then it’s forks out, and off for refurb mmmm, wonder what I find up front !!!!
Post by shaunthe2nd on Sept 24, 2019 19:09:25 GMT 1
Hope its nothing as serious as the above, the red seat and the large LC logos! Glad your getting it sorted and hope you get a chance to ride it before the bad weather.
Post by perazzi350 on Sept 24, 2019 20:00:29 GMT 1
Hope its nothing as serious as the above, the red seat and the large LC logos! Glad your getting it sorted and hope you get a chance to ride it before the bad weather. wont get to ride it this year still got loads to do
Post by loctite on Sept 24, 2019 20:13:27 GMT 1
ive been following your story,hopefully you will be sorted soon enough and next year will be your year and youve not fell out of love with the bike,
Post by perazzi350 on Sept 24, 2019 22:15:47 GMT 1
No I wont fall out of love with LCs I just need to get it right to make it into what I want..I Knowq for sure all the engine is good Rob rebuilt it and kindly gave me a disc with all the photo's Thanks Rob Steve
Post by perazzi350 on Dec 21, 2019 20:55:11 GMT 1
Just got wheels back from painter, now a satin black much better IMO fitted sprocket and new disc
Post by perazzi350 on Dec 21, 2019 21:03:29 GMT 1
Post by perazzi350 on Dec 21, 2019 21:05:49 GMT 1
Last photo not meant to be on, it was just something I tried the junked!
Post by 4l04ever on Dec 22, 2019 11:15:08 GMT 1
Getting there slowly :-)
The fan will only be of benefit when sitting in traffic, as the airflow from moving along will be far higher than the fan can produce.
Post by perazzi350 on Dec 22, 2019 17:01:30 GMT 1
Getting there slowly :-) The fan will only be of benefit when sitting in traffic, as the airflow from moving along will be far higher than the fan can produce. Hi Rob yes getting there slowly, there is a lot of traffic in todays times so just fitted it to help out a bit when stuck in it, tank and panels etc all at the painters said it would be about end of Feb so it will fit in ok for getting finished in spring
Post by perazzi350 on Dec 29, 2019 18:23:10 GMT 1
Post by perazzi350 on Dec 29, 2019 18:25:10 GMT 1
Post by tell7437 on Dec 29, 2019 23:28:54 GMT 1
What did you try as a coil cover, didn't notice it was different till I was working on mine today
