Post by radioman on Aug 15, 2019 12:11:34 GMT 1
Clip 363-13133-01
A tiny clip that fits on the oil pump cable drum. Does this stop the cable coming out of the groove ?
Had a TDR & never remember this clip.
Thanks Keith
Post by mattybeckett on Aug 26, 2019 14:27:47 GMT 1
Clip 363-13133-01 A tiny clip that fits on the oil pump cable drum. Does this stop the cable coming out of the groove ? Had a TDR & never remember this clip. Thanks Keith Yes, obviously make sure the cable runs underneath it as I have seen a few which have been fitted incorrectly with cable over the top, which will eventually cause the cable to fray and break 😱
Post by radioman on Aug 26, 2019 16:07:29 GMT 1
Clip 363-13133-01 A tiny clip that fits on the oil pump cable drum. Does this stop the cable coming out of the groove ? Had a TDR & never remember this clip. Thanks Keith Yes, obviously make sure the cable runs underneath it as I have seen a few which have been fitted incorrectly with cable over the top, which will eventually cause the cable to fray and break 😱 Thanks for info, tiny but important item. Keith
Post by midlifecrisisrd on Aug 26, 2019 16:10:49 GMT 1
If it's like ypvs and if engines there is no "clip" on the pulley
The return spring locates on to the pulley and the cable has to be under that
The only other clip in that area is the one that holds the cable onto the case
