Post by mickt1964 on Aug 14, 2019 21:51:47 GMT 1
What is the best way of protecting the gasket faces, bolt faces etc on the heads and barrels etc etc before painting.
And what is the best paint for the job
Post by shaunthe2nd on Aug 14, 2019 22:17:05 GMT 1
Masking tape! Take your time putting it on and shaping it.
I usually paint and cure with Plastikote BBQ paint but I'm told the new formulae isn't up to the job so I'm interested in replies too.
Post by midlifecrisisrd on Aug 15, 2019 8:40:39 GMT 1
What bike?
Makes a difference to what I use as matt/gloss depending on model
Post by mickt1964 on Aug 15, 2019 8:48:06 GMT 1
Its an standard LC head and barrels
Post by jessy03 on Aug 15, 2019 10:17:22 GMT 1
I used some Wurth paint, got it from yambits, it says Matt finish but is more satin, not petrol proof
Post by headcoats on Aug 15, 2019 10:31:16 GMT 1
I used Plastikote BBQ paint too but keep petrol away from it , just put an old towel under the fuel tap when getting it on and off
Had it on the cam cover of the Bonneville for about 4 years and has been very durable
I masked off using normal masking tape and cardboard to go over the larger areas with just the tape on the edges
Post by midlifecrisisrd on Aug 15, 2019 15:56:19 GMT 1
I tend to use vht barrel paint satin black with the grey vht primer
If gloss I paint the head with simoniz or hycote gloss black and for the barrels I use halfords brush engine enamel. Easy to stipple on the surface and easy to clean off any you get on the gasket surfaces with a Stanley blade while soft
Post by rigga on Aug 15, 2019 20:40:30 GMT 1
Might be getting senile, but didn't Dusty find something in Halfords that worked really well? Petrol proof too I think.
DUSTY!!!!! Where are you
Post by midlifecrisisrd on Aug 15, 2019 20:48:22 GMT 1
Might be getting senile, but didn't Dusty find something in Halfords that worked really well? Petrol proof too I think. DUSTY!!!!! Where are you It was hycote engine paint but gloss only Steve
Post by pdxjim on Aug 16, 2019 6:06:13 GMT 1
PJ1 Engine Case paint in satin.
Bake in the oven at 200f for an hour and it's petrol proof(ish).
Post by gprd on Aug 16, 2019 19:23:58 GMT 1
I've painted mine with some Simoniz Tough Black. It went on well, 24hr cure, I'll let you all know what it's like.
