Post by radioman on Aug 12, 2019 20:07:12 GMT 1
Jobs like removing the rear suspension to repair or maintain. Looks like you need to remove the exhaust to get a stand under the frame tubes, engine cradle. Front wheel, single point lift paddock stand under fork stem. Rear standard paddock stand.
Any advice welcome. Keith
Post by midlifecrisisrd on Aug 12, 2019 20:41:52 GMT 1
An ABBA stand should do the trick Well worth the money and you get different fitting kits for different bikes The pic shows the stand and the roller kit Steve
Post by midlifecrisisrd on Aug 12, 2019 20:45:03 GMT 1
Should also say it has a swing arm removal kit in the pic which is a bobbin kit you fit to the foot peg mounts so you can take the swing arm pivot out
Post by radioman on Aug 12, 2019 21:06:32 GMT 1
Thanks Steve will look into that stand,sounds just the job. Mine supposed to have done 9000 miles but as hard to maintain suspension bushes bet your life not been touched. & had been laying around at a West London emporium ?
A note to others if buying a R1Z or 31k etc take a good torch & look in the tank. Mine was good, 3 others there were shot. + the others had 030 CDI's !
Post by abar121 on Aug 17, 2019 12:58:56 GMT 1
Oh no, if it's one of those Motorcycle giant sheds, good luck!
I've looked at a few and vowed never to go back. How they can say they only stock what they are willing to ride themselves, is a joke.
There have been quite a few disappointed peeps on here..
I used as abba stand as above. They have the fitment if you call them.
