Post by philmill on Jul 28, 2019 13:51:59 GMT 1
As I've fitted dinky little LED indicators on my hybrid I thought I'd buy a relay that is for LED, however I can't get anything to work. So while looking at a picture on eBay last night it seems to show the relay having 2 terminals not 3, I had bought a 3 pin unit as the plug was 3! So which is correct please, also, the 3rd wire on the plug goes nowhere except a plug, and there is what appears to be a matching wire ready for that to plug into, is that correct`??
Thanks, Phil
Post by tacky1 on Jul 28, 2019 16:28:08 GMT 1
I use the 2 pin cheap Chinese relays with the little adjuster for blink speed, The 3rd wire is for the indicator cancelling unit that turns off the indicators after you drive a bit.
Post by philmill on Jul 29, 2019 14:38:17 GMT 1
I have the cancelling unit, but the circuit seems dead, I will order a two pin relay and see if that make a difference. So the wire should be connected to the other one under the tank? seems strange they did just have it wired that way.
Phil
Post by philmill on Jul 29, 2019 15:41:26 GMT 1
These wires should be connected like this??
