Post by noonster on Jul 23, 2019 21:11:02 GMT 1
Some advise please
Fitted another shock to my bike,because there was excessive movement when lifting the back wheel up.
This is better but still got some movement when lifting. Adjusted the shock don't make much difference.
Should you have a little movement doing this
Post by 4l04ever on Jul 23, 2019 21:25:09 GMT 1
Could be play where pins go in frame or swingarm. Watch both ends while lifting to see if there is movement...
Post by earthman on Jul 23, 2019 22:26:52 GMT 1
A few of us have found play in the pins/holes, bound to happen after 30+ years of use I guess. Either shim or lathe up a pin from scratch I guess.
Post by Deleted on Jul 23, 2019 22:51:36 GMT 1
Mine does it a bit, its the lower pin moving in the holes on the swing arm. I guess, as said, 38 years of wear and tear. When I get chance I'll take the swing arm out, replace the pin and bush the arm.
Post by jon on Jul 24, 2019 20:17:41 GMT 1
A few of us have found play in the pins/holes, bound to happen after 30+ years of use I guess. Either shim or lathe up a pin from scratch I guess. Please don’t take this the wrong way as I assure you it’s not meant to offend but educate. You’re not the only one. We have lathes at work and it makes me cringe when anyone says ‘lathe it down’. To put it into context let’s consider a car. The noun for a car is ‘car’. The verb to use it is ‘drive’. Now you wouldn’t say ‘I cared my car into work this morning’ would you? You’d say ‘I drove my car into work’. The verb to use a lathe is ‘turn’. So really you should be saying ‘I turned a piece of metal down on my lathe’. Really unimportant to most, but to me it just sounds so wrong. Jon
Post by earthman on Jul 24, 2019 21:49:08 GMT 1
Maybe I should have said, make a pin to fit from scratch then.
Post by reedpete on Jul 25, 2019 17:15:23 GMT 1
A few of us have found play in the pins/holes, bound to happen after 30+ years of use I guess. Either shim or lathe up a pin from scratch I guess. Please don’t take this the wrong way as I assure you it’s not meant to offend but educate. You’re not the only one. We have lathes at work and it makes me cringe when anyone says ‘lathe it down’. To put it into context let’s consider a car. The noun for a car is ‘car’. The verb to use it is ‘drive’. Now you wouldn’t say ‘I cared my car into work this morning’ would you? You’d say ‘I drove my car into work’. The verb to use a lathe is ‘turn’. So really you should be saying ‘I turned a piece of metal down on my lathe’. Really unimportant to most, but to me it just sounds so wrong. Jon Yes, and also actually quite difficult to ‘turn up’ a few parts ....although part of our colloquial language.
