Post by looey on Jul 4, 2019 11:34:40 GMT 1
What's the chances of finding the part of an LC seat that has the 2 threads poking through for the seat catch to bolt to the underneath of the seat.
Got a seat here to refurb and one of the studs is snapped off for the catch to bolt onto.
Anyone know if they're handed or the same both sides ? (haven't got the seat apart yet).
Cheers
Post by LC_BOTT on Jul 4, 2019 14:13:45 GMT 1
I made a couple of new ones, a small bit of flat plate filed to shape, and drilled/welded a couple of 6mm bolts to them. Not handed, so both the same.
Post by jon on Jul 4, 2019 18:54:56 GMT 1
What's the chances of finding the part of an LC seat that has the 2 threads poking through for the seat catch to bolt to the underneath of the seat. Got a seat here to refurb and one of the studs is snapped off for the catch to bolt onto. Anyone know if they're handed or the same both sides ? (haven't got the seat apart yet). Cheers As LC BOTT suggests, I could make you one if your stuck. Jon
Post by looey on Jul 4, 2019 19:05:14 GMT 1
Thanks for the offer Jon, We're in the IOM at the moment, so don't have access to all my usual tools. We're not stuck, I can leave this one as is for now. I'll keep and eye out and let you know if I get totally stuck Much appreciate
Post by jon on Jul 4, 2019 19:34:06 GMT 1
I have a seat base with no foam or cover, so can see what it would have to look like from the brackets that are on it.
Let me know as it looks like an easy bit to fabricate.
Post by donkeychomp on Jul 5, 2019 22:24:39 GMT 1
Jon, is it easy to fabricate the tang also?
Post by JonW on Jul 6, 2019 0:18:36 GMT 1
Post by donkeychomp on Jul 6, 2019 22:09:31 GMT 1
I went through the whole page to be sure but all I could find was one picture with the tang as it looked before the repair. I can plastic weld so that's not an issue for me but wondering what you used to build the tang up with?
Post by JonW on Jul 6, 2019 23:49:55 GMT 1
I didnt take one, but rest assured the two prongs were long gone. I used some plastic I had lying around from a rego holder, but you will find something im sure.
Post by donkeychomp on Jul 7, 2019 22:47:52 GMT 1
Cheers Jon!
Post by badger69 on Sept 5, 2021 19:17:04 GMT 1
Jon, is it easy to fabricate the tang also? Alex Its plastic but yes you can add to it with a soldering iron and the right plastic to build it up or make a steel one like the Gully's have. This is one I built up before the final sanding: img]http://www.2smoked.com/Yamaha_RDLC_Restoration_-_350_conversion_from_250_files/droppedImage_24.jpg [/img] from about 1/3rd way down this page: www.2smoked.com/Yamaha_RDLC_Restoration_-_350_conversion_from_250.html[/quote]
Post by 4l04ever on Sept 5, 2021 19:47:12 GMT 1
Hi donkey.... I have some bits of a chopped up seat base. I can send you a bit
Post by 4l04ever on Sept 5, 2021 19:48:55 GMT 1
I also purchased another white plastic non-LC Yamaha seat base for extra material
Post by donkeychomp on Sept 5, 2021 21:10:49 GMT 1
Cheers but I got a tang from Alan and screwed it on. Fits perfectly.
