Post by 4ce on Jun 24, 2019 19:31:26 GMT 1
Hi All Been painting a few bit s satin black and noticed a few of you heat them in the oven. What temp (electric) and for how long. will need to wait till shes out, Oh and will it smell?
Post by shaunthe2nd on Jun 24, 2019 19:53:43 GMT 1
I've used Plastikote bbq paint, black satin a few times. I find it remains satin if you don't over bake it after applying. Max 40mins at 120 degrees should do it. Much longer and starts to matt off a bit.
And yes, it smells!
Post by raven13 on Jun 24, 2019 20:53:54 GMT 1
Hi All Been painting a few bit s satin black and noticed a few of you heat them in the oven. What temp (electric) and for how long. will need to wait till shes out, Oh and will it smell? only bake if using high temp or bbq paint. don't try bake normal spray painted items in your oven. Its gonna smell (a lot) but if its not high temp its gonna come out screwed
Post by 4ce on Jun 24, 2019 22:51:59 GMT 1
Ok, thanks
Post by dusty350 on Jun 25, 2019 7:23:27 GMT 1
In the past I've got the oven fairly hot, then turned it off and put the parts in, so they go in hot but are gradually cooling. Seems to cure the paint well and not affect the finish. Dusty
Post by mak595 on Jun 25, 2019 8:07:56 GMT 1
I painted the brake calipers on my katana build with simoniz engine enamel, cured them at 80○ for 20 mins, seemed to work well...
Post by 4l04ever on Jun 25, 2019 12:18:00 GMT 1
I only have a gas oven. Used Gas mark 5 for 20 mins then left in overnight to cool off.
richb
Post by richb on Jun 25, 2019 13:09:51 GMT 1
She'd punch my lights out if I tried this at home. Years ago when I was single I heated a chain grease tin up on the stove and dropped chain in, then for some reason took the short cut through the lounge on way to back garden tripped on mat and spilt molten chain grease all over the carpet. That took some getting out, thankfully heavily patterned carpet and the slight stain it did leave was not that visible. The joys of being single.
Post by pdxjim on Jun 25, 2019 16:15:52 GMT 1
I do the PJ1 Fast Black Engine Case paint in my gas oven at 200*F for about an hour.
Cures very hard and doesn't seem to change the finish much.
Post by midlifecrisisrd on Jun 25, 2019 16:36:04 GMT 1
She'd punch my lights out if I tried this at home. Years ago when I was single I heated a chain grease tin up on the stove and dropped chain in, then for some reason took the short cut through the lounge on way to back garden tripped on mat and spilt molten chain grease all over the carpet. That took some getting out, thankfully heavily patterned carpet and the slight stain it did leave was not that visible. The joys of being single. Your not cunning enough Wait till she is out and do it then explain the smell by saying you decided to clean the oven while she was out but must have used the wrong stuff as it didn't work and it stunk when you turned it on to dry 😉 Steve
Post by shaunthe2nd on Jun 25, 2019 17:26:13 GMT 1
...and whilst your at it, put all the grubby plastics in the dishwasher to get all the oil and grime off and blame that on the dirt from the oven trays you tried to clean after the oven problem.
