Post by stusco on Jun 22, 2019 15:55:31 GMT 1
Went out on my lc (pv engine f2 loom and switch gear) and I found that my indicators and low beam don’t work everything else is working,there is no power going to the low beam but it’s at the hi-lo switch ,I can’t work out the indicator as my head can’t be arsed so I’m hoping someone will bail me out logic says it’s the switch gear as it has both faulty lights in it
Post by midlifecrisisrd on Jun 22, 2019 16:17:48 GMT 1
First check if the indicator relay has 12v on it.
Both in and out
If high beam works it's likely the hi/lo switch is knackered
Check the connector plug.
Post by midlifecrisisrd on Jun 22, 2019 16:18:51 GMT 1
Oh and I may have an f2 switch you can try
Post by stusco on Jun 22, 2019 16:49:10 GMT 1
Cheers Steve I’ll check it tomorrow the wife at the pink concert so I’m off out wi the boys
Post by stusco on Jun 23, 2019 15:02:16 GMT 1
It turns out the switchgear connector in the head light was loose
