Post by jon on May 20, 2019 7:20:26 GMT 1
Hi all,
I’ve not got an LC manual, just a YPVS one.
How much coolant is in a dry system?
I’m assuming you remove the lower coolant pipe to drain most out then the water pump cover and cylinder jacket bolts?
Post by shaunthe2nd on May 20, 2019 8:23:44 GMT 1
1.8 litre according to the manual. Mine took a bit less, maybe due to crud build up in the radiator etc.
I usually drain by removing the bolts on each side of the barrels, one at a time, then finish off by disconnecting the lower hose. Remove the radiator cap when you do it.
