Post by JonW on May 13, 2019 4:48:01 GMT 1
We all know the 1UA cylinder is different to the 31K, and most people cite that the exhaust port height is the difference, is that all it is? Or is there more to these cylinder changes?
Post by headcoats on May 13, 2019 7:38:52 GMT 1
Does one have a lower inlet floor too ??
Post by midlifecrisisrd on May 13, 2019 8:45:29 GMT 1
Don't quote me but I'm sure the inlets are slightly different too
I really don't understand why they fitted a higher exhaust port to a bike that made max power at 8.5k
They seemed to have a higher tune on the barrel then destroyed that with electronics and pipes
I'm sure Slinger told me the exhaust port duration on the 1ua barrel was too long and the long stroke conversion corrected that.
Come to think about it if you have the exhaust port closed later but the same squish and chamber volume surely you have reduced the compression
Also heard it said many a time that tuners prefer the 31k barrel
Post by JonW on May 13, 2019 8:49:09 GMT 1
Yes, I've heard people say the 31K is the one tuners prefer, but my problem is that Ive a 'set' of cyls that have been run as a pair for a while on a bike, yet they are not a set. I was thinking it might be possible to at least get them to be closer to 'the same' with a bit of gentle porting, and I assumed it was easier to make a 31K into a 1UA than vice versa lol
Post by midlifecrisisrd on May 13, 2019 8:53:27 GMT 1
Yes, I've heard people say the 31K is the one tuners prefer, but my problem is that Ive a 'set' of cyls that have been run as a pair for a while on a bike, yet they are not a set. I was thinking it might be possible to at least get them to be closer to 'the same' with a bit of gentle porting, and I assumed it was easier to make a 31K into a 1UA than vice versa lol Yes a tuner would be able to match them Just grind the markings off After You need to dyno it first with 1 plug out each time to find out which one was better 🤣 Steve
Post by JonW on May 13, 2019 13:39:23 GMT 1
Haha, now thats a good idea Steve... LOL! I was hoping I might be able to match them myself if it was just the exhaust port height
Post by jessy03 on May 13, 2019 14:28:06 GMT 1
Jess
Post by marrcel on May 13, 2019 15:17:36 GMT 1
Thanks Jesse What about the piston holes are 31k and 1ua the same?
Post by JonW on May 14, 2019 6:37:49 GMT 1
Thanks Jess, That does seem like most of the dimensions on the 1UA could be ground out of the 31k cylinder, there are only a few small bits that would be different then, hmm, tempting.
Post by reggieperrin on May 14, 2019 12:43:29 GMT 1
Interesting picture as the only real big difference is the length of the lower transfer ports. The exhaust height difference is only 1mm, although understandably that would make a difference.
Post by bare on May 14, 2019 17:08:28 GMT 1
Have both types 'on hand'. UA cyls do have the visibly lowered inlet ports. BUT.. what the maps don't reveal is that while the Sleeves are cut lower.. the Ali casting mold wasn't changed . Soooo the lower port area in the sleeve faces Cast ali barrel. One could? port (grind out) the barrel so air could flow there.. but the ali is Thin there and with small assurance of not hitting air in process. More than a Bit stoopid to be honest.
Post by reggieperrin on May 14, 2019 17:12:11 GMT 1
Have both types 'on hand'. UA cyls do have the visibly lowered inlet ports. BUT.. what the maps don't reveal is that while the Sleeves are cut lower.. the Ali casting mold wasn't changed . Soooo the lower port area in the sleeve faces Cast ali barrel. More than a Bit stoopid to be honest. Thanks Bare, very useful info. I would imagine that there must be even a small amount of difference though, even if the thickness of the liner is the only transfer area. Without having both in front of me to be able to see, is there scope for removal of the aluminium casting to allow the beneficial use of the lower ports?
Post by bare on May 14, 2019 17:16:31 GMT 1
I won't even try. Curiously; competent porting work involves Raising the top of the inlet ports.. a lot. Rarely (if ever) lowering them.. Something to think about :-)
Post by urbantangleweed on May 15, 2019 16:34:10 GMT 1
There is a difference, in the same way as 34D is different to 36C, but get one next to the other, and you'd see they're both virtually the same thing, just different.
