Post by marrcel on May 8, 2019 11:09:20 GMT 1
Just put a fresher engine in. Only the bottom end. The barrels with new pistons were run for a 1000mls are used again. I do a cycle anyway to check if coolant stays in. My question is. Are heatcycles nescesary with reused pistons and barrels?
Post by Deleted on May 8, 2019 11:59:57 GMT 1
No need to heat cycle. Cranks run on roller bearings. If you had fitted new rings then yes a couple of heat cycles would be a good idea.
