Post by ukcalling on May 7, 2019 18:25:33 GMT 1
Another plea for advise please
I have a 350lc fitted with LC2 forks. Just rebuilt the forks and put it back together but worried when fitting the 4L0 wheel the forks need to pull together quite a long way when doing up the axle
It has the original lc wheel, right hand spacer and speedo drive.
Does the wheel fit with these original bits or do I need the LC2 speedo drive and or right hand wheel spacer?
Thanks Nick
Post by midlifecrisisrd on May 7, 2019 18:30:50 GMT 1
Undo the yokes and rotate the stanchions to check they ain't bent
You don't want to be pulling them in
I thought the lc and lc2 Speedo drives were the same so maybe you need a rh spacer
Post by ukcalling on May 7, 2019 18:38:39 GMT 1
Thanks for thd reply
I did put a rule against legs when off and they looked straight.
I cannot find a parts list for an LC2 to check the part numbers, any idea where I can find one as Fowlers don't seem to list it ?
Thanks Nick
Post by oldelsieboy on May 7, 2019 18:44:16 GMT 1
LC & LC2 share the same front wheel spacer & speedo drive.
OEB
Post by dave1963 on May 7, 2019 19:11:37 GMT 1
Got 31k forks and standard lc wheel in my lc all standard lc spacers all ok
Post by ukcalling on May 7, 2019 19:27:34 GMT 1
Thanks chaps for the feedback
Will go check again legs are straight
Nick
Post by darboots on May 8, 2019 8:41:23 GMT 1
Post by wangwang on May 8, 2019 12:37:34 GMT 1
I have two bikes with this set up, no problems. Have you checked the yokes? Have you got a brace fitted?
Post by ukcalling on May 8, 2019 19:01:52 GMT 1
Will have a look at the yokes - not done that yet
Do have a fork brace fitted but put on post tightening up the wheel as was the mudguard
Thanks Nick
